I'm working on backporting the 5.8 mainline driver for the TAS2110 into my project. One thing I noticed is that minimum number of channels is specified as 2:
.name = "tas2562-amplifier", .id = 0, .playback = { .stream_name = "ASI1 Playback", .channels_min = 2, .channels_max = 2, .rates = SNDRV_PCM_RATE_8000_192000, .formats = TAS2562_FORMATS, },
I'm also wondering how/if the driver handles the IRQ. I was previously using this driver:
But am running into problems with the IRQ constantly happening with the TDM Clock Error bit set.
Will I be able to use the mainline driver for a mono TAS2110?
Hi Chris,
Have you tried to use this other set of files? tas256xsw-android/tas2562-android-driver - Software for TAS256x on Android platforms - Android software for Texas Instruments TAS2562. (ti.com)
The link you shared is for stereo driver, the one above here is mono.
-Ivan Salazar
Applications Engineer - Low Power Audio & Actuators
Ivan,
Thanks for pointing me to that. I'll try to integrate it, it looks like there are a number of changes needed due to using a newer kernel version. Just curious, is there any reason to use that driver instead of the mainline driver created by Dan Murphy, referenced in this post: https://e2e.ti.com/support/audio/f/6/t/933995?TAS2110-TAS2110-TAS2562-device-tree-for-imx8m-mini ?
Hi, Chris,
Our team is checking your latest question. We will provide a feedback as soon as possible.
Luis Fernando Rodríguez S.
Hi Chris,
I think the files were purposed to be implemented in different platforms.
I can check with our SW team on this question.
-Ivan Salazar
Hi Chris,
Do you have any further questions about your original question?
Please let us know if this thread is closed. Thanks.
-Ivan Salazar
Hi Ivan,
I'm not sure I understand the last couple messages. Should I be able to use the mainline kernel driver? Or is it recommended to use the ti repo linked above?
Chris Garren
Hi, Chris,
Ivan is taking a look at your questions. He will provide a response shortly.
Hi Chris,
Sorry for late response, we're actively supporting the drivers from ti repo, I would suggest to take it from there.
-Ivan Salazar
