TAS5806M: TAS5806M HFP Profile with ESP32
Part Number: TAS5806M
Hi everyone I have created an a2dp project using an esp32 and the TAS5806M. The bluetooth audio is fine and I have no problems. Now I am trying to integrate the HFP profile to be able to make hands-free calls. I set the sample rate to 16Khz 16 bit and 1 channel but the audio in call feels really bad. I also enabled wide band speech on the esp32 for better quality but nothing. Advice? Thanks.
  • Hello Francesco,
    Can you provide a schematic and register configuration.
    Luis
  • Hello Luis,
    This is a register configuration for TAS5806M:
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x00, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7f, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x03, 0x02 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x01, 0x11 ));
    vTaskDelay(100 / portTICK_RATE_MS);
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x03, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x46, 0x11 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x78, 0x80 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x61, 0x0b ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x60, 0x01 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7d, 0x11 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7e, 0xff ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x00, 0x01 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x51, 0x05 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x02, 0x01 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x53, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x54, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x66, 0x86 )); // EQReg
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7f, 0x8c ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x00, 0x2a ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x24, 0x00 )); // Volume Left = 0 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x25, 0x80 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x26, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x27, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x28, 0x00 )); // Volume Right = 0 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x29, 0x80 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x2a, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x2b, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x00, 0x29 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x18, 0x00 )); // Input Mixer Left to left = 0 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x19, 0x80 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1a, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1b, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1c, 0x00 )); // Input Mixer Right to left = -110 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1d, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1e, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1f, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x20, 0x00 )); // Input Mixer Left to right = -110 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x21, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x22, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x23, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x24, 0x00 )); // Input Mixer Right to right = 0 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x30, 0x00 )); // Volume Alpha = 3 ms
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x31, 0xe2 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x32, 0xc4 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x33, 0x6b ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x00, 0x2c ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x0c, 0x00 )); // Left Input to Left Level Meter = -110 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x0d, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x0e, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x0f, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x10, 0x00 )); // Right Input to Left Level Meter = -110 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x11, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x12, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x13, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x14, 0x00 )); // Left Output to Left Level Meter = 0 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x15, 0x80 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x16, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x17, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x18, 0x00 )); // Right Output to Left Level Meter = -110 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x19, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1c, 0x00 )); // Output Crossbar Left to Amp Left = 0 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1d, 0x80 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x20, 0x00 )); // Output Crossbar Right to Amp Left = -110 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x28, 0x00 )); // Output Crossbar Left to Amp Right = -110 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x29, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x2c, 0x00 )); // Output Crossbar Right to Amp Right = 0 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x2d, 0x80 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x2e, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x2f, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x34, 0x00 )); // Output Crossbar Left to I2S Left = 0 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x35, 0x80 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x36, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x37, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x38, 0x00 )); // Output Crossbar Right to I2S Left = -110 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x39, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3a, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3b, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x48, 0x00 )); // Output Crossbar Left to I2S Right = -110 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x49, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4a, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4b, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4c, 0x00 )); // Output Crossbar Right to I2S Right = 0 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4d, 0x80 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4e, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4f, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5c, 0x00 )); // AGL Release Rate: 0.001
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5d, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5e, 0xae ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5f, 0xc3 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x60, 0x01 )); // AGL Attack Rate: 0.2
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x61, 0x12 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x62, 0x6e ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x63, 0x98 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x64, 0x04 )); // AGL Threshold: 0 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x65, 0x8a ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x66, 0xa7 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x67, 0x0b ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x68, 0xc0 )); // AGL OnOff: 0
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x69, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6a, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6b, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6c, 0x04 )); // AGL Softening Alpha: 0.55 ms
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6d, 0xc1 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6e, 0xff ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6f, 0x93 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x00, 0x2d ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x18, 0x7b )); // AGL Softening Omega: 0.55 ms
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x19, 0x3e ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1b, 0x6d ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1c, 0x00 )); // Level Meter Time Constant = 1000 ms
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1e, 0xae ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1f, 0xc3 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x20, 0x00 )); // Left Input to Right Level Meter = -110 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x24, 0x00 )); // Right Input to Right Level Meter = -110 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x25, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x28, 0x00 )); // Left Output to Right Level Meter = -110 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x2c, 0x00 )); // Right Output to Right Level Meter = 0 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x00, 0x31 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x48, 0x40 )); // FIR Data
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4d, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x50, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x51, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x52, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x55, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x56, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x57, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x58, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x59, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5a, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5b, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5e, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5f, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x60, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x61, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x62, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x63, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x64, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x65, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x66, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x67, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x68, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6c, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6d, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6e, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6f, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x70, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x71, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x72, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x73, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x74, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x75, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x76, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x77, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x78, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x79, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7a, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7b, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7c, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7d, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7e, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x00, 0x32 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x08, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x09, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x0a, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x0b, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x15, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x2d, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x31, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x32, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x33, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x35, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3c, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3d, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3e, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3f, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x40, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x41, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x42, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x43, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x44, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x45, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x46, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x47, 0x00 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x00, 0x33 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x00, 0x34 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x00, 0x35 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7f, 0xaa ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x00, 0x24 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x18, 0x08 )); // Biquad - BQ1 Left - Filter: All Pass Frequency: 20.609043823243237 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x2c, 0x08 )); // Biquad - BQ2 Left - Filter: Equalizer (Q Factor) Frequency: 84 Hz QVal: 2.75 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x30, 0xf0 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x31, 0x08 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x32, 0x6b ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x33, 0x63 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x34, 0x07 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x35, 0xf7 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x36, 0xd3 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x37, 0xe0 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x38, 0x0f ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x39, 0xf7 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3a, 0x94 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3b, 0x9d ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3c, 0xf8 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3d, 0x08 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3e, 0x2c ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3f, 0x20 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x40, 0x08 )); // Biquad - BQ3 Left - Filter: Equalizer (Q Factor) Frequency: 170 Hz QVal: 2.75 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x44, 0xf0 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x45, 0x11 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x46, 0x84 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x48, 0x07 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x49, 0xef ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4a, 0x7e ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4b, 0x91 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4c, 0x0f ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4d, 0xee ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4e, 0x7c ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x50, 0xf8 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x51, 0x10 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x52, 0x81 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x53, 0x6f ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x54, 0x08 )); // Biquad - BQ4 Left - Filter: Equalizer (Q Factor) Frequency: 1200 Hz QVal: 2.7489 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x58, 0xf0 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x59, 0xa2 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5a, 0xce ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5b, 0x27 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5c, 0x07 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5d, 0x8e ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5e, 0x38 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5f, 0xf4 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x60, 0x0f ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x61, 0x5d ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x62, 0x31 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x63, 0xd9 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x64, 0xf8 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x65, 0x71 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x66, 0xc7 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x67, 0x0c ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x68, 0x08 )); // Biquad - BQ5 Left - Filter: Equalizer (Q Factor) Frequency: 8000 Hz QVal: 2.75 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6c, 0xf9 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6d, 0x47 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6e, 0x91 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6f, 0xba ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x70, 0x05 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x71, 0x70 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x72, 0xdc ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x73, 0x8b ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x74, 0x06 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x75, 0xb8 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x76, 0x6e ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x77, 0x46 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x78, 0xfa ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x79, 0x8f ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7a, 0x23 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7b, 0x75 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7c, 0x08 )); // Biquad - BQ6 Left - Filter: Equalizer (Q Factor) Frequency: 12000 Hz QVal: 2.75 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x00, 0x25 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x0c, 0x04 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x0d, 0x72 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x0e, 0x10 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x0f, 0x09 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x14, 0xfb ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x15, 0x8d ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x16, 0xef ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x17, 0xf7 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x18, 0x08 )); // Biquad - BQ7 Left - Filter: All Pass Frequency: 12000 Hz QVal: 2.75 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x2c, 0x08 )); // Biquad - BQ8 Left - Filter: All Pass Frequency: 12000 Hz QVal: 2.75 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x40, 0x08 )); // Biquad - BQ9 Left - Filter: All Pass Frequency: 19615.00277270495 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x54, 0x08 )); // Biquad - BQ10 Left - Filter: All Pass Frequency: 1000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x68, 0x08 )); // Biquad - BQ11 Left - Filter: All Pass Frequency: 1000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7c, 0x08 )); // Biquad - BQ12 Left - Filter: All Pass Frequency: 1000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x00, 0x26 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x18, 0x08 )); // Biquad - BQ13 Left - Filter: All Pass Frequency: 1000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x2c, 0x08 )); // Biquad - BQ14 Left - Filter: All Pass Frequency: 1000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x40, 0x08 )); // Biquad - BQ15 Left - Filter: All Pass Frequency: 1000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x54, 0x08 )); // Biquad - BQ1 Right - Filter: All Pass Frequency: 1000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x68, 0x08 )); // Biquad - BQ2 Right - Filter: All Pass Frequency: 1000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7c, 0x08 )); // Biquad - BQ3 Right - Filter: All Pass Frequency: 1000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x00, 0x27 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x18, 0x08 )); // Biquad - BQ4 Right - Filter: All Pass Frequency: 1000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x2c, 0x08 )); // Biquad - BQ5 Right - Filter: All Pass Frequency: 1000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x40, 0x08 )); // Biquad - BQ6 Right - Filter: All Pass Frequency: 1000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x54, 0x08 )); // Biquad - BQ7 Right - Filter: All Pass Frequency: 1000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x68, 0x08 )); // Biquad - BQ8 Right - Filter: All Pass Frequency: 1000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7c, 0x08 )); // Biquad - BQ9 Right - Filter: All Pass Frequency: 1000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x00, 0x28 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x18, 0x08 )); // Biquad - BQ10 Right - Filter: All Pass Frequency: 1000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x2c, 0x08 )); // Biquad - BQ11 Right - Filter: All Pass Frequency: 1000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x40, 0x08 )); // Biquad - BQ12 Right - Filter: All Pass Frequency: 1000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x54, 0x08 )); // Biquad - BQ13 Right - Filter: All Pass Frequency: 1000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x68, 0x08 )); // Biquad - BQ14 Right - Filter: All Pass Frequency: 1000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7c, 0x08 )); // Biquad - BQ15 Right - Filter: All Pass Frequency: 1000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x00, 0x2e ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x08, 0x00 )); // DRC Band1 Mixer Gain: 1
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x09, 0x80 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x0c, 0x00 )); // DRC Band2 Mixer Gain: 1
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x0d, 0x80 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x10, 0x00 )); // DRC Band3 Mixer Gain: 1
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x11, 0x80 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x48, 0x00 )); // Low F2 BQ2 - Filter: Low Pass-ButterWorth 2 Frequency: 200 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x49, 0x05 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4a, 0x83 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4b, 0x2a ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4d, 0x05 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4e, 0x83 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4f, 0x2a ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x52, 0x83 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x53, 0x2a ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x54, 0x7d ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x55, 0xa1 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x56, 0x77 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x57, 0x3d ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x58, 0x84 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x59, 0xa7 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5a, 0x04 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5b, 0xdf ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x58, 0x02 )); // DRC Settings of band3: attack: 1 ms, release: 10 ms, energy: 1 ms, Region1 - Threshold: -124 dB, Offset: 0 dB, Ratio: 1 Region2 - Threshold: -60 dB, Offset: 0 dB, Ratio: 1 Region3 - Threshold: 0 dB, Offset: 0 dB, Ratio: 100
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x59, 0xa3 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5a, 0x9a ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5b, 0xcc ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5c, 0x02 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5d, 0xa3 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5e, 0x9a ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5f, 0xcc ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x61, 0x44 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x62, 0x32 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x63, 0x13 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6c, 0xff ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6d, 0x81 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6e, 0x47 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6f, 0xae ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x70, 0xf9 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x71, 0x06 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x72, 0x21 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x73, 0xa9 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x74, 0xfe ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x75, 0x01 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x76, 0xc0 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x77, 0x79 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x00, 0x2b ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x34, 0x00 )); // DRC Settings of band1: attack: 25 ms, release: 50 ms, energy: 25 ms, Region1 - Threshold: -124 dB, Offset: 0 dB, Ratio: 1 Region2 - Threshold: -60 dB, Offset: 0 dB, Ratio: 1 Region3 - Threshold: 0 dB, Offset: 0 dB, Ratio: 100
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x35, 0x1b ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x36, 0x4b ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x37, 0x98 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x39, 0x1b ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3a, 0x4b ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3b, 0x98 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3d, 0x0d ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3e, 0xa6 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3f, 0x86 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x48, 0xff ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x49, 0x81 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4a, 0x47 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4b, 0xae ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4c, 0xf9 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4d, 0x06 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4e, 0x21 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4f, 0xa9 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x50, 0xfe ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x51, 0x01 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x52, 0xc0 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x53, 0x79 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x34, 0x00 )); // Low F1 BQ1 - Filter: Low Pass-ButterWorth 2 Frequency: 200 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x35, 0x05 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x36, 0x83 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x37, 0x2a ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x39, 0x05 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3a, 0x83 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3b, 0x2a ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3d, 0x05 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3e, 0x83 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3f, 0x2a ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x40, 0x7d ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x41, 0xa1 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x42, 0x77 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x43, 0x3d ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x44, 0x84 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x45, 0xa7 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x46, 0x04 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x47, 0xdf ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x30, 0x02 )); // DRC Settings of band2: attack: 1 ms, release: 100 ms, energy: 1 ms, Region1 - Threshold: -124 dB, Offset: 0 dB, Ratio: 1 Region2 - Threshold: -60 dB, Offset: 0 dB, Ratio: 1 Region3 - Threshold: 0 dB, Offset: 0 dB, Ratio: 100
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x31, 0xa3 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x32, 0x9a ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x33, 0xcc ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x34, 0x02 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x35, 0xa3 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x36, 0x9a ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x37, 0xcc ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x39, 0x06 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3a, 0xd3 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x3b, 0x72 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x44, 0xff ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x45, 0x81 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x46, 0x47 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x47, 0xae ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x48, 0xf9 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x49, 0x06 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4a, 0x21 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4b, 0xa9 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4c, 0xfe ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4d, 0x01 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4e, 0xc0 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4f, 0x79 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5c, 0x7d )); // Mid F1 BQ1 - Filter: High Pass-ButterWorth 2 Frequency: 200 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5d, 0xa6 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5e, 0xfa ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5f, 0x66 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x60, 0x82 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x61, 0x59 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x62, 0x05 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x63, 0x9a ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x64, 0x7d ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x65, 0xa6 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x66, 0xfa ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x67, 0x66 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x68, 0x7d ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x69, 0xa1 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6a, 0x77 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6b, 0x3d ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6c, 0x84 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6d, 0xa7 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6e, 0x04 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x6f, 0xdf ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x70, 0x7d )); // Mid F2 BQ2 - Filter: High Pass-ButterWorth 2 Frequency: 200 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x71, 0xa6 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x72, 0xfa ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x73, 0x66 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x74, 0x82 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x75, 0x59 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x76, 0x05 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x77, 0x9a ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x78, 0x7d ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x79, 0xa6 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7a, 0xfa ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7b, 0x66 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7c, 0x7d ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7d, 0xa1 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7e, 0x77 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x7f, 0x3d ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x08, 0x84 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x09, 0xa7 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x0a, 0x04 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x0b, 0xdf ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x0c, 0x58 )); // High F1 BQ1 - Filter: High Pass-ButterWorth 2 Frequency: 4000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x0d, 0x3b ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x0e, 0x2f ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x0f, 0x3d ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x10, 0xa7 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x11, 0xc4 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x12, 0xd0 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x13, 0xc3 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x14, 0x58 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x15, 0x3b ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x16, 0x2f ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x17, 0x3d ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x18, 0x51 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x19, 0xe5 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1a, 0x7f ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1b, 0x65 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1c, 0xc2 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1d, 0xde ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1e, 0x41 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1f, 0xd5 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x20, 0x58 )); // High F2 BQ2 - Filter: High Pass-ButterWorth 2 Frequency: 4000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x21, 0x3b ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x22, 0x2f ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x23, 0x3d ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x24, 0xa7 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x25, 0xc4 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x26, 0xd0 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x27, 0xc3 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x28, 0x58 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x29, 0x3b ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x2a, 0x2f ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x2b, 0x3d ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x2c, 0x51 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x2d, 0xe5 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x2e, 0x7f ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x2f, 0x65 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x30, 0xc2 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x31, 0xde ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x32, 0x41 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x33, 0xd5 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x40, 0x06 )); // Mid F3 BQ3 - Filter: Low Pass-ButterWorth 2 Frequency: 4000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x41, 0x55 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x42, 0xaf ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x43, 0xd8 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x44, 0x06 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x45, 0x55 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x46, 0xaf ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x47, 0xd8 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x48, 0x06 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x49, 0x55 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4a, 0xaf ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4b, 0xd8 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4c, 0x51 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4d, 0xe5 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4e, 0x7f ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4f, 0x65 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x50, 0xc2 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x51, 0xde ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x52, 0x41 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x53, 0xd5 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x54, 0x06 )); // Mid F4 BQ4 - Filter: Low Pass-ButterWorth 2 Frequency: 4000 Hz QVal: 0.71 Bandwidth: 1000 Hz
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x55, 0x55 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x56, 0xaf ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x57, 0xd8 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x58, 0x06 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x59, 0x55 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5a, 0xaf ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5b, 0xd8 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5c, 0x06 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5d, 0x55 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5e, 0xaf ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x5f, 0xd8 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x60, 0x51 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x61, 0xe5 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x62, 0x7f ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x63, 0x65 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x64, 0xc2 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x65, 0xde ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x66, 0x41 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x67, 0xd5 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x18, 0x07 )); // THD Clipper: 0 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x19, 0xec ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1a, 0xa9 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1b, 0xcd ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1c, 0x04 )); // THD Finevolume Left: 0 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1d, 0x09 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1e, 0xc2 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x1f, 0xb1 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x20, 0x04 )); // THD Finevolume Right: 0 dB
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x21, 0x09 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x22, 0xc2 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x23, 0xb1 )); //Register Tuning
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x4c, 0x30 ));
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x77, 0x00 )); // Headphone
    ESP_ERROR_CHECK(tas5806m_write_byte( 0x03, 0x03 ));
  • Hello Francesco,
    The TAS5806 supports 32, 44.1, 48, 88.2, 96 kHz sample rates. 16kHz sample rate is not supported for this device. This is probably why you are noticing issues with the audio.
    best regards,
    Luis
  • Hello Luis,
    I had already thought it was for this, now I have confirmed.
    Thank you very much for your time.
