Hi Team,
One of my customer is using TPA2025D1, they reported, if they weak pull up the ENABLE pin, saying ~10Mohms, there are some middle voltage was observed on the pin. As previous feedback from BU, there is no internal pull-up pull down resistor inside of the device, so it could be the leakage. But in our datasheet, we do not have the spec on the leakage current on EN pin. Can you share the data, to see how big the resistor can be.
Peter Wei
