Part Number: PCM2903
I'm using this part for Full duplex headset communication. Is anyone having a crosstalk problem where you hear yourself echo when speaking through the microphone? If yes, is there a solution to this issue?
Thank you.
Niko
Thank you.
Niko
Hi Niko,
Are you referring to the sidetone feature where you can monitor the audio captured by the mic in the headset? There is a slight delay between speech and the sidetone signal, but if you are hearing a longer duration echo this may be another issue.
Zak
