Other Parts Discussed in Thread: TLV320ADC3101
Team,
I would like to know the sentence meaning of red rectangle.
Is the result correct?
Roy
Team,
Roy
Hi Roy,
The full scale input of the ADC is 1.414Vrms so for single ended, there is a 6dB boost to get .707Vrms up to 1.414Vrms.
Aaron Estrada
Hi Roy,
When an analog input is configured for single-ended use, yes, there is a 6dB boost. As mentioned above, this is get achieve a full scale input to the ADC.
Aaron Estrada
Hi Aaron,
I still have questions. In my measurement, we input the single ended 10mVrms. The output signal may be 6bB(internal)+32dB(set), 10m*2*40~800mVrms
But my result is 400mVrms. Do i have any misunderstanding?
Roy
Hi Roy,
Thank you for raising this issue in E2E, let me discuss with Aaron myself.
Hi Aaron,
Sorry for interrupting, please see the modified diagram below as TLV320ADC3101 converts analog input in dBFS.
Could you check if this measurement result is correct?
Hello Sam and Roy,
Apologies for the delay here. I have been out of office the last few days and have just returned.
Doing the math, for SE I would expect ~-5dB and for differential ~-11dB with 32dB of gain applied. Your calculations look correct as with mine, no errors were accounted for.
Aaron Estrada
