Part Number: TLV320AIC3254
To whom it may concern,
We have run some thermal cycling and find that when initialising the codec at -40 C, although the ADC seems to operate as expected, the DAC appears to be locked up.
We suspect that perhaps the codec is failing to configure correctly via the SPI bus, but timings measured at room temperature appear to meet the those stated in Section 8.18 of the datasheet.
Could you confirm that these parameters in Section 8.18 are guaranteed over the full operating temperature range of the codec?
Is there anything further internally to the codec that should be accounted for when operating at temperature extremes (i.e. PLL settling time, start-up lockout times, analog reference startup times etc.) ?
Look forward to hearing from you.
Many Thanks,
Bhav
