TLV320AIC3106: Initial register setting
Part Number: TLV320AIC3106
Hi Team,
My customer is design in TLV320AIC3106 and starts to build up function. So, they need initial register settings and could team help to support this case?
In this design, both MCLK and BCLK input clock is 12MHz, WCLK comes from SOC as well, sampling rate is 48KHz, I2S mode. As to the input/out configuration I will send SCH by mail.
Thanks a lot.
Vincent Chen
  • Hi Vincent,
    Providing some initial register settings is something I would be happy to send over. If you would like, you can add me as a friend and send the schematic via private message.
    Based on the inputs used, I will sent the appropriate configuration.
    Aaron Estrada
