I'm having problems with the TAS5342L shutting down during heavy music loads. At the point of "shut down" the VDD has dipped to 27.5v from its nominal of 29v. Can you tell me what the TAS5342L undervoltage protection (UVP) threshold is? Can this threshold be changed to allow a little more "ripple" in the power supply at times? I am able to eliminate the problem by adding a 6800uf cap on VDD at the amplifier. However I would rather not add this expense to the board and would like to find a little more elegant solution. And yes, before you ask, during the shut down times the amplifier is well into clipping.
