Other Parts Discussed in Thread: PCM1792A, DAC81001, DAC91001, DAC8811, DAC11001A
Greetings!
I'd like to know if it's possible to bypass the PCM1789 oversampling digital filter (ie, not use it).
I was planning to take advantage of its high resolution in a closed loop control application, but the group delay of 19 or 28/fs will severly limit the bandwidth. For instance, considering only the 19/fs delay at 192KHz, maximum BW should be 10KHz. For 28/fs it's even worse at 6.8KHz.
Vitor.
