kai klaas69 very kindly provided me with data and analysis regarding the LM4766 Amplifier section of my circuit.
Now that I have modelled the circuit with components, is it possible that it could be thoroughly checked, please?
As well as my circuit I will attach the relevant information from the product pdf.
Thank you so very much.
Christopher J James
Thank yiou, so very much.
CJJ
Hi James,
What's the VEE power value? I found the Cm cap voltage is 6.3V. Please take care if the cap voltage is suitable.
Others is fine.
Derek
Dear Derek,
On further reflection, I must confess I hadn't noticed that had slipped my attention.
I have duly amended the original circuit and list of components as above.
Is the rest of the circuit in order though, please?
Christopher
Hi Christopher,
Can you tell me the VCC and VEE power value?
From the design, I think fine, but I need to double confirm the power supply.
Derek
Dear Derek,
+15 Volts and -15 Volts plus a Ground.
Part of the circuit only requires a single supply but other parts yield better results with a parallel supply.
Thank you so much.
Christopher
Dear Christopher,
Thank you.
I suggest add 1uF and 0.1uF decoupling caps on VCC.
Others is fine.
Derek
Dear Derek,
I thought that Cs was adding a 0.1uF, and I have added a further 1uF as a duplicate CIN as per the amended image above.
If you are able to check that this is what you kindly advised, I would be most sincerely grateful.
I have done a similar thing on another part of my circuit, but it had not triggered me to repeat it elsewhere,
Thank you once again for your kind guidance.
Christopher
Dear Derek,
I will ask no more of you, for I have been advised that my comments were offensive.
I promise on my life that they were not intended to be.
Thank you.
Christopher
