Part Number: PCM1753
Other Parts Discussed in Thread: PCM1754
I would like to set a register of pcm1753 using spi communication
Is there an example related to this?
That waveform looks correct to me. Can you confirm that the device is correctly powered? What frequency is your SCK, LRCK, and BCK?
Paul
Do you need SCK,LRCK,BCK waveforms?
Unfortunately, I2S-related waveforms cannot be measured.
However, when tested using PCM1754 on the same board, the wave file output was smooth.
After changing to PCM1753, it is not outputted.
