Part Number: ADC128S052-Q1
We are using the ADC "ADC128S052-Q1" via SPI.
We wanted to know if you could support us with a sample code.
Also, an example with higher sampling frequency will be helpful.
Soumya
Soumya
Unfortunately there is no sample code available.
this device does not have any internal registers, thus all communications are actively done through SDI.
I suggest using a known DC input to compare output data with expected output.
For timing, I suggest following the timing diagram available in the datasheet . the clock frequency controls both the sampling rate and the throughput.
Cynthia
