DAC80508: Multiple signal generators in parallel.
Part Number: DAC80508
Other Parts Discussed in Thread: SN74ACT244
Hi team,
I am using DAC80508 to generate a sine wave.
But I've another device SN74ACT244 working in parallel with the DAC to generate a sine wave.
The SN74ACT244  SN74ACT244  will be driven from a PWM signal from the processor. So I hope I can generate a neat sine wave out of SN74ACT144.
I'll use only one of the devices at a time. I'll bypass any one of the signal generators at a time. The signal generated from these devices is fed to a common circuit.
When the DAC is working (SN74ACT244 is disabled by setting the nOE pin high), the loading effect on the signal due to the SN74ACT244 will be very low like in the order of (Ioz=2.5uA).
Will the DAC create any loading problem on my signal when my SN74ACT244 is working?.
