Part Number: ADS8586S
Other Parts Discussed in Thread: ADS8588S, , TINA-TI
Hi Team,
Is there is any Evaluation module available for ADC ADS8586 ?
Vineeth
There is an EVM available for the 8-channel ADS8588S. The performance on channels 1-6 of this EVM will directly match the performance of an ADS8586S device, except for the slightly reduced 200kSPS vs. 250kSPS sampling rates.
Hi Collin,
Thank you for your response. I will take a look at EVM you suggested, if the only difference is the reduced sampling rate then for my testing purpose I think it wont be a problem. It can be connected through USB and coding to it can be done using CCS right ?
Vineeth
Hi Vineeth,
The EVM is meant for evaluation purposes of the ADC where you'll be able to observe the digital waveforms and AC & DC performance metrics using the GUI data analysis modules. The USB connection does not interface with CCS or any other IDE for code development or GUI modifications. You'll need to bring the required digital connections over separately into the ADS8588 daughtercard from the host processor you'll be developing with to test your code.
Hi Collin,
Actually it was a mistake from my side that I asked about the USB interface to code the EVM. Also is there is any Pspice model available for this ADS8586S as I wanted to develop the schematic
Vineeth
Yes, there is a SPICE model for the ADS8588 that will work for this product:
