Part Number: AFE4404
Hi there.
I need to determine the DC values of the signal, I cannot use a high pass, this phenomenon seems to be a thermal drift, some other idea to correct this situation.
Thank you so much
Hi there.
Thank you so much
Hi Camilo,
How does the data look like over 10k samples right after the AFE is configured vs the 10k samples after a couple of minutes? Do you see this thermal drift in both the data?
If the drift is present only initially, then our suggestion would be to delay the data processing and this delay would be a function of the LED current.
Also can you calculate the perfusion index (AC/DC) at a few locations in the 10k samples window and check if the index remains a constant?
Hi Camilo,
Since I did not hear back from you for quite some time, I assume that your issue has been solved.
Note that I'll go ahead and close this thread. Replying to the thread will re-open it if necessary at some point.
