ADS8588S: ADS8588S
Part Number: ADS8588S
Hi TI,
I read the data sheet of ADS8588S and couldn't understand if we could use the inputs as differential inputs or not ?
if yes, can we use 8 differential input channels ?
Mamzi
  • Hi Mamzi,
    Unfortunately, ADS8588S does not support a differential input and its negative input pin (AIN_nGND) should be connected to the ground (GND), please refer to the parameter range below which is also specified in the data sheet.
    Can you please let me know what the maximum sampling rate you need? and also what's your input signal range? Can you accept an 8-ch simultaneous sampling Delta-Sigma ADC? thanks.
    Dale
  • Dale,
    Thank you so much for your quick reply. We are almost done with the design. Just wanted to double check and see if there is any other option to exercise.
    Thank you.
