ADS1299 gain not updating.
Other Parts Discussed in Thread: ADS1299
I am using the ADS1299 evaluation board to record EEG data and display it on Labview. We are using a gain of x24 and the Byte output for every electrode is 8388608.
This value does not change when I reduce the gain to any other value.
I am changing the PGA gain using the CH[1:8]SET control register.  If you need extra details please let me know.
Thank you,
Rommel.
  • Hi Rommel,
    Welcome to the E2E forum !!!
    It looks like your input is causing the ADC output to saturate at the negative full-scale (ADC output code of 0x800000). Please make sure you are setting the correct common-mode voltage bias to the the device input channels? Please refer to sections 9.3.1.2 and 9.3.1.3.1 in the datasheet for more information on the analog input requirements.
    -TC
