ADC128S102: DOUT Signal Before Track State
Part Number: ADC128S102
Good Day. I have a customer who is working with ADC128S102. Please see below his query for your reference. Thank you very much.
I am working on the FPGA code to read signals from ADC128S102 part. The datasheet mentioned "The ADC's DOUT pin is in a high impedance state when CS is high and is active when CS is low".
DOUT pins is logic high or logic low when in high impedance state? Can i assume that DOUT pins is always logic high when CS is high and is always logic low when CS is low before the track state?
Ray Vincent
  • Hi Ray,
    DOUT is neither high nor low on the ADC128S102 /CS line is high.  It is in a high impedance state as the datasheet mentions.  This means the DOUT is essentially floating - there is nothing driving it to any particular logic level.  When you pull /CS low, the DOUT is driven low through the first four falling clock edges while the device is in track mode.
