Other Parts Discussed in Thread: TPS797
My customer has a question for ADS124S06.
Due to their board space limitation, they want to use the simplest way to make 3.3V from 5V for DVDD (only DVDD, not including IOVDD. IOVDD=5V in this case).
They think the simplest way is using just a resistor divider.
The datasheet shows only supply current data for DVDD+IOVDD without SPI communication.
How much current is required for only DVDD including SPI communication case?
Is using just a resistor divider from 5V to 3.3V acceptable idea for this device to DVDD?
Or should they absolutely use a LDO or a shunt regulator?
Oba
