Part Number: DAC81404
Other Parts Discussed in Thread: DAC8771
I want to make a +/-20 mA analog current loop driver with DAC81404. I'm planning to use a 50ohm shunt resistor that connected to sense lines through a opamp which has 5x gain.Thus, DAC will generate +-20mA in +-5V full scale range. Is this convenient method for this purpose or can you suggest different solutions? Also, I want to use high power stage with transistors like evaluation module design, can I use with my current drive approach?
