Part Number: ADS1261EVM
Other Parts Discussed in Thread: ADS1261
Hi team,
I got a question from customer.
There is no response to data collection. The following is the relevant log information. Please help analyze it.
2022-03-03 17:42:17.6481|DEBUG|DeltaSigmaEvalConsole.UIControlViewModel|Processing 'ID from the transmit queue
2022-03-03 17:42:17.6580|DEBUG|DeltaSigmaEvalConsole.UIControlViewModel|Transmitted command as 2 bytes
2022-03-03 17:42:19.6168|WARN|TI.DeltaSigma.CommandConfig.DeviceConfiguration|Command ID not found in list
2022-03-03 17:42:19.9225|DEBUG|DeltaSigmaEvalConsole.UIControlViewModel|Received device ID string: ADS1261 May 22 2018 11:42:28
2022-03-03 17:42:19.9354|INFO|TI.DeltaSigma.CommandConfig.DeviceConfiguration|Successfully imported 1 tools
2022-03-03 17:42:19.9728|INFO|TI.PA.ADC.RegisterMap.RegisterMapClass|-------------------------------- Import of XML File Completed
2022-03-03 17:42:20.0182|INFO|DeltaSigmaEvalConsole.UIControlViewModel|No hardware settings files found for this device.
2022-03-03 17:42:20.0182|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Beginning import of script configuration file: C:\Users\sl\Documents\DSEvalSW\Devices\ADS1261\scripts\Basic Startup.xml
2022-03-03 17:42:20.0182|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Successfully imported script with 6 commands
2022-03-03 17:42:20.0182|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Beginning import of script configuration file: C:\Users\sl\Documents\DSEvalSW\Devices\ADS1261\scripts\Bridge measurement - EXT REF with AC excitation.xml
2022-03-03 17:42:20.0182|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Successfully imported script with 16 commands
2022-03-03 17:42:20.0182|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Beginning import of script configuration file: C:\Users\sl\Documents\DSEvalSW\Devices\ADS1261\scripts\Bridge measurement - EXT REF with CHOP.xml
2022-03-03 17:42:20.0182|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Beginning import of script configuration file: C:\Users\sl\Documents\DSEvalSW\Devices\ADS1261\scripts\Bridge measurement - EXT REF.xml
2022-03-03 17:42:20.0182|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Successfully imported script with 15 commands
2022-03-03 17:42:20.0182|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Beginning import of script configuration file: C:\Users\sl\Documents\DSEvalSW\Devices\ADS1261\scripts\Bridge measurement - supply REF with CHOP.xml
2022-03-03 17:42:20.0182|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Beginning import of script configuration file: C:\Users\sl\Documents\DSEvalSW\Devices\ADS1261\scripts\Bridge measurement - supply REF.xml
2022-03-03 17:42:20.0182|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Successfully imported script with 14 commands
2022-03-03 17:42:20.0182|INFO|DeltaSigmaEvalConsole.UIControlViewModel|Successfully imported 6 scripts.
2022-03-03 17:42:20.0182|INFO|DeltaSigmaEvalConsole.UIControlViewModel|------------------------------------ Import of pre-defined scripts COMPLETE
2022-03-03 17:42:20.0282|INFO|DeltaSigmaEvalConsole.UIControlViewModel|Successfully imported 0 scripts.
2022-03-03 17:42:20.0282|INFO|DeltaSigmaEvalConsole.UIControlViewModel|------------------------------------ Import of user-defined scripts COMPLETE
2022-03-03 17:42:38.7318|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Unable to connect to a socket: Attempt 1
2022-03-03 17:42:47.3989|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Client transmission error: {0}
2022-03-03 17:42:59.7620|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Unable to connect to a socket: Attempt 2
2022-03-03 17:43:20.8067|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Unable to connect to a socket: Attempt 3
2022-03-03 17:43:41.8606|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Unable to connect to a socket: Attempt 4
2022-03-03 17:44:02.9043|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Unable to connect to a socket: Attempt 5
2022-03-03 17:44:23.9377|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Unable to connect to a socket: Attempt 6
2022-03-03 17:44:44.9689|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Unable to connect to a socket: Attempt 7
2022-03-03 17:45:05.9957|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Unable to connect to a socket: Attempt 8
2022-03-03 17:45:27.0286|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Unable to connect to a socket: Attempt 9
2022-03-03 17:45:48.0740|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Unable to connect to a socket: Attempt 10
2022-03-03 17:45:48.0749|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|**** Unable to establish a connection with a socket!
2022-03-03 17:45:48.0749|INFO|TI.DeltaSigma.CommSocket.AppSocketClient|Terminating the client socket!
2022-03-03 17:48:05.8931|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Beginning import of script configuration file: C:\Users\sl\Documents\DSEvalSW\Devices\ADS1261\scripts\Basic Startup.xml
2022-03-03 17:48:05.8931|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Successfully imported script with 6 commands
2022-03-03 17:48:05.8931|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Beginning import of script configuration file: C:\Users\sl\Documents\DSEvalSW\Devices\ADS1261\scripts\Bridge measurement - EXT REF with AC excitation.xml
2022-03-03 17:48:05.8931|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Successfully imported script with 16 commands
2022-03-03 17:48:05.8931|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Beginning import of script configuration file: C:\Users\sl\Documents\DSEvalSW\Devices\ADS1261\scripts\Bridge measurement - EXT REF with CHOP.xml
2022-03-03 17:48:05.8931|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Beginning import of script configuration file: C:\Users\sl\Documents\DSEvalSW\Devices\ADS1261\scripts\Bridge measurement - EXT REF.xml
2022-03-03 17:48:05.8931|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Successfully imported script with 15 commands
2022-03-03 17:48:05.8931|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Beginning import of script configuration file: C:\Users\sl\Documents\DSEvalSW\Devices\ADS1261\scripts\Bridge measurement - supply REF with CHOP.xml
2022-03-03 17:48:05.8931|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Beginning import of script configuration file: C:\Users\sl\Documents\DSEvalSW\Devices\ADS1261\scripts\Bridge measurement - supply REF.xml
2022-03-03 17:48:05.8931|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Successfully imported script with 14 commands
2022-03-03 17:48:05.8931|INFO|DeltaSigmaEvalConsole.UIControlViewModel|Successfully imported 6 scripts.
2022-03-03 17:48:05.8931|INFO|DeltaSigmaEvalConsole.UIControlViewModel|------------------------------------ Import of pre-defined scripts COMPLETE
2022-03-03 17:48:05.8931|INFO|DeltaSigmaEvalConsole.UIControlViewModel|Successfully imported 0 scripts.
2022-03-03 17:48:05.8931|INFO|DeltaSigmaEvalConsole.UIControlViewModel|------------------------------------ Import of user-defined scripts COMPLETE
2022-03-03 17:48:12.0891|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Beginning import of script configuration file: C:\Users\sl\Documents\DSEvalSW\Devices\ADS1261\scripts\Basic Startup.xml
2022-03-03 17:48:12.0891|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Successfully imported script with 6 commands
2022-03-03 17:48:12.0891|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Beginning import of script configuration file: C:\Users\sl\Documents\DSEvalSW\Devices\ADS1261\scripts\Bridge measurement - EXT REF with AC excitation.xml
2022-03-03 17:48:12.0891|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Successfully imported script with 16 commands
2022-03-03 17:48:12.0891|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Beginning import of script configuration file: C:\Users\sl\Documents\DSEvalSW\Devices\ADS1261\scripts\Bridge measurement - EXT REF with CHOP.xml
2022-03-03 17:48:12.0891|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Beginning import of script configuration file: C:\Users\sl\Documents\DSEvalSW\Devices\ADS1261\scripts\Bridge measurement - EXT REF.xml
2022-03-03 17:48:12.0891|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Successfully imported script with 15 commands
2022-03-03 17:48:12.0891|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Beginning import of script configuration file: C:\Users\sl\Documents\DSEvalSW\Devices\ADS1261\scripts\Bridge measurement - supply REF with CHOP.xml
2022-03-03 17:48:12.0891|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Beginning import of script configuration file: C:\Users\sl\Documents\DSEvalSW\Devices\ADS1261\scripts\Bridge measurement - supply REF.xml
2022-03-03 17:48:12.0891|INFO|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Successfully imported script with 14 commands
2022-03-03 17:48:12.0891|INFO|DeltaSigmaEvalConsole.UIControlViewModel|Successfully imported 6 scripts.
2022-03-03 17:48:12.0891|INFO|DeltaSigmaEvalConsole.UIControlViewModel|------------------------------------ Import of pre-defined scripts COMPLETE
2022-03-03 17:48:12.0891|INFO|DeltaSigmaEvalConsole.UIControlViewModel|Successfully imported 0 scripts.
2022-03-03 17:48:12.0891|INFO|DeltaSigmaEvalConsole.UIControlViewModel|------------------------------------ Import of user-defined scripts COMPLETE
2022-03-03 17:49:20.6813|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Client transmission error: {0}
2022-03-03 17:49:24.6490|INFO|DeltaSigmaEvalConsole.UIControlViewModel|USB Transmit handler is terminating.
2022-03-03 17:42:17.6281|TRACE|DeltaSigmaEvalConsole.UIControlViewModel|NOTIFICATION: USBTXHEARTBEAT:TRUE
2022-03-03 17:42:17.6281|TRACE|DeltaSigmaEvalConsole.UIControlViewModel|NOTIFICATION: USBRXRUNNING:TRUE
2022-03-03 17:42:17.6481|TRACE|DeltaSigmaEvalConsole.UIControlViewModel|Sending remote called command: ID
2022-03-03 17:42:17.6481|TRACE|DeltaSigmaEvalConsole.UIControlViewModel|USB TX - Sending: ID
2022-03-03 17:42:19.9354|TRACE|TI.DeltaSigma.CommandConfig.DeviceConfiguration|Beginning import of command configuration file: C:\Users\sl\Documents\DSEvalSW\Devices\ADS1261\config\commands\Command Config File.xml
2022-03-03 17:42:19.9354|TRACE|TI.DeltaSigma.CommandConfig.DeviceConfiguration|Successfully imported 24 commands
2022-03-03 17:42:19.9354|TRACE|TI.DeltaSigma.CommandConfig.DeviceConfiguration|Successfully imported 3 folders
2022-03-03 17:42:19.9354|TRACE|TI.DeltaSigma.CommandConfig.DeviceConfiguration|Import of configuration file concluded with status = True
2022-03-03 17:42:19.9999|TRACE|DeltaSigmaEvalConsole.UIControlViewModel|Register change for ID value 128
2022-03-03 17:42:19.9999|TRACE|DeltaSigmaEvalConsole.UIControlViewModel|-------------------------------- BEGIN REG CHANGE
2022-03-03 17:42:19.9999|TRACE|RegisterMapClient.RegisterViewModel|INITIALIZIING REGISTER CONTROLS: ID = 80
2022-03-03 17:42:19.9999|TRACE|RegisterMapClient.RegisterViewModel|Set DEV_ID combobox to 8 (current value = 80)
2022-03-03 17:42:19.9999|TRACE|RegisterMapClient.RegisterViewModel|Set REV_ID combobox to 0 (current value = 80)
2022-03-03 17:42:19.9999|TRACE|RegisterMapClient.RegisterViewModel|END INITIALIZIING REGISTER CONTROLS
2022-03-03 17:42:19.9999|TRACE|DeltaSigmaEvalConsole.UIControlViewModel|-------------------------------- END REG CHANGE
2022-03-03 17:42:20.0182|TRACE|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Import of script file concluded with status = True
2022-03-03 17:42:37.8610|TRACE|DeltaSigmaEvalConsole.UIControlViewModel|Register change for MODE0 value 36
2022-03-03 17:42:37.8610|TRACE|DeltaSigmaEvalConsole.UIControlViewModel|-------------------------------- BEGIN REG CHANGE
2022-03-03 17:42:37.8610|TRACE|RegisterMapClient.RegisterViewModel|INITIALIZIING REGISTER CONTROLS: MODE0 = 24
2022-03-03 17:42:37.8610|TRACE|RegisterMapClient.RegisterViewModel|Set DR combobox to 4 (current value = 24)
2022-03-03 17:42:37.8610|TRACE|RegisterMapClient.RegisterViewModel|Set FILTER combobox to 4 (current value = 24)
2022-03-03 17:42:37.8610|TRACE|RegisterMapClient.RegisterViewModel|END INITIALIZIING REGISTER CONTROLS
2022-03-03 17:42:37.8610|TRACE|DeltaSigmaEvalConsole.UIControlViewModel|-------------------------------- END REG CHANGE
2022-03-03 17:42:47.3989|TRACE|RegisterMapClient.RegisterViewModel|-------------------------BEGIN REGISTER UPDATE----------------------------------------------
2022-03-03 17:42:47.3989|TRACE|RegisterMapClient.RegisterViewModel|BEGIN REGISTER SYNC: MODE0 - 00100100
2022-03-03 17:42:47.3989|TRACE|RegisterMapClient.RegisterViewModel|ELEMENT UPDATE: DR to 00111010
2022-03-03 17:42:47.3989|TRACE|RegisterMapClient.RegisterViewModel|ELEMENT UPDATE: FILTER to 00111010
2022-03-03 17:42:47.3989|TRACE|RegisterMapClient.RegisterViewModel|FINALIZE REGISTER UPDATE: value to 92:2022/3/3 17:42:47
2022-03-03 17:42:47.4033|TRACE|RegisterMapClient.RegisterViewModel|-------------------------END REGISTER UPDATE----------------------------------------------
2022-03-03 17:42:52.3772|TRACE|DeltaSigmaEvalConsole.UIControlViewModel|Register change for MODE1 value 1
2022-03-03 17:42:52.3772|TRACE|DeltaSigmaEvalConsole.UIControlViewModel|-------------------------------- BEGIN REG CHANGE
2022-03-03 17:42:52.3772|TRACE|RegisterMapClient.RegisterViewModel|INITIALIZIING REGISTER CONTROLS: MODE1 = 01
2022-03-03 17:42:52.3772|TRACE|RegisterMapClient.RegisterViewModel|Set 0 combobox to 0 (current value = 01)
2022-03-03 17:42:52.3772|TRACE|RegisterMapClient.RegisterViewModel|Set CHOP combobox to 0 (current value = 01)
2022-03-03 17:42:52.3772|TRACE|RegisterMapClient.RegisterViewModel|Set CONVRT combobox to 0 (current value = 01)
2022-03-03 17:42:52.3772|TRACE|RegisterMapClient.RegisterViewModel|Set DELAY combobox to 1 (current value = 01)
2022-03-03 17:42:52.3772|TRACE|RegisterMapClient.RegisterViewModel|END INITIALIZIING REGISTER CONTROLS
2022-03-03 17:42:52.3772|TRACE|DeltaSigmaEvalConsole.UIControlViewModel|-------------------------------- END REG CHANGE
2022-03-03 17:42:53.9388|TRACE|DeltaSigmaEvalConsole.UIControlViewModel|Register change for MODE0 value 92
2022-03-03 17:42:53.9388|TRACE|DeltaSigmaEvalConsole.UIControlViewModel|-------------------------------- BEGIN REG CHANGE
2022-03-03 17:42:53.9388|TRACE|RegisterMapClient.RegisterViewModel|INITIALIZIING REGISTER CONTROLS: MODE0 = 5C
2022-03-03 17:42:53.9388|TRACE|RegisterMapClient.RegisterViewModel|Set DR combobox to 11 (current value = 5C)
2022-03-03 17:42:53.9388|TRACE|RegisterMapClient.RegisterViewModel|Set FILTER combobox to 4 (current value = 5C)
2022-03-03 17:42:53.9388|TRACE|RegisterMapClient.RegisterViewModel|END INITIALIZIING REGISTER CONTROLS
2022-03-03 17:42:53.9388|TRACE|DeltaSigmaEvalConsole.UIControlViewModel|-------------------------------- END REG CHANGE
2022-03-03 17:43:11.7918|TRACE|DeltaSigmaEvalConsole.UIControlViewModel|Launch C:\Program Files (x86)\Texas Instruments\DSEvalSW\Clients\AnalysisEngine\AnalysisEngine.exe
2022-03-03 17:48:05.8931|TRACE|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Import of script file concluded with status = True
2022-03-03 17:48:12.0891|TRACE|TI.DeltaSigma.CommandConfig.Script.DeviceScriptFile|Import of script file concluded with status = True
2022-03-03 17:49:24.6490|TRACE|DeltaSigmaEvalConsole.UIControlViewModel|NOTIFICATION: USBTXHEARTBEAT:FALSE
2022-03-03 17:42:38.7318|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Unable to connect to a socket: Attempt 1|System.Net.Sockets.SocketException (0x80004005): �������ӷ���һ��ʱ���û����ȷ�����ӵ�����û�з�Ӧ�����ӳ���ʧ�ܡ� 10.62.214.217:11000
�� System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
�� System.Net.Sockets.Socket.Connect(EndPoint remoteEP)
�� TI.DeltaSigma.CommSocket.AppSocketClient.StartClient(Int32 port)
2022-03-03 17:42:47.3989|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Client transmission error: {0}|System.Net.Sockets.SocketException (0x80004005): ��������û�����Ӳ���(��ʹ��һ�� sendto ���÷������ݱ�����ʱ)û���ṩ��ַ�����ͻ�������ݵ�����û�б����ܡ�
�� TI.DeltaSigma.CommSocket.AppSocketClient.TransmitToServer(String dataToSend, Socket sendSocket)
2022-03-03 17:42:59.7620|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Unable to connect to a socket: Attempt 2|System.Net.Sockets.SocketException (0x80004005): �������ӷ���һ��ʱ���û����ȷ�����ӵ�����û�з�Ӧ�����ӳ���ʧ�ܡ� 10.62.214.217:11000
2022-03-03 17:43:20.8067|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Unable to connect to a socket: Attempt 3|System.Net.Sockets.SocketException (0x80004005): �������ӷ���һ��ʱ���û����ȷ�����ӵ�����û�з�Ӧ�����ӳ���ʧ�ܡ� 10.62.214.217:11000
2022-03-03 17:43:41.8606|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Unable to connect to a socket: Attempt 4|System.Net.Sockets.SocketException (0x80004005): �������ӷ���һ��ʱ���û����ȷ�����ӵ�����û�з�Ӧ�����ӳ���ʧ�ܡ� 10.62.214.217:11000
2022-03-03 17:44:02.9043|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Unable to connect to a socket: Attempt 5|System.Net.Sockets.SocketException (0x80004005): �������ӷ���һ��ʱ���û����ȷ�����ӵ�����û�з�Ӧ�����ӳ���ʧ�ܡ� 10.62.214.217:11000
2022-03-03 17:44:23.9377|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Unable to connect to a socket: Attempt 6|System.Net.Sockets.SocketException (0x80004005): �������ӷ���һ��ʱ���û����ȷ�����ӵ�����û�з�Ӧ�����ӳ���ʧ�ܡ� 10.62.214.217:11000
2022-03-03 17:44:44.9689|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Unable to connect to a socket: Attempt 7|System.Net.Sockets.SocketException (0x80004005): �������ӷ���һ��ʱ���û����ȷ�����ӵ�����û�з�Ӧ�����ӳ���ʧ�ܡ� 10.62.214.217:11000
2022-03-03 17:45:05.9957|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Unable to connect to a socket: Attempt 8|System.Net.Sockets.SocketException (0x80004005): �������ӷ���һ��ʱ���û����ȷ�����ӵ�����û�з�Ӧ�����ӳ���ʧ�ܡ� 10.62.214.217:11000
2022-03-03 17:45:27.0286|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Unable to connect to a socket: Attempt 9|System.Net.Sockets.SocketException (0x80004005): �������ӷ���һ��ʱ���û����ȷ�����ӵ�����û�з�Ӧ�����ӳ���ʧ�ܡ� 10.62.214.217:11000
2022-03-03 17:45:48.0740|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Unable to connect to a socket: Attempt 10|System.Net.Sockets.SocketException (0x80004005): �������ӷ���һ��ʱ���û����ȷ�����ӵ�����û�з�Ӧ�����ӳ���ʧ�ܡ� 10.62.214.217:11000
2022-03-03 17:45:48.0749|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|**** Unable to establish a connection with a socket!|
2022-03-03 17:49:20.6813|ERROR|TI.DeltaSigma.CommSocket.AppSocketClient|Client transmission error: {0}|System.NullReferenceException: δ�������������õ������ʵ����
Thank you very much for your help.
