Other Parts Discussed in Thread: ADS1299,
Hi Experts,
The Pin Configuration and Functions found on page 5 of the datasheet shows the full pin out for ADS1299, since ADS1299-4 is also using the same package (64-Pin) can you confirm if Pins 1 through 8 (channels 5 through 8) in a 4-channel device must also be connected to AVDD, or they should simply be left floating?
Are these pins not connected internally or should I still write the configuration registers to power those down?
Thank you.
Marvin
