Part Number: DAC60504
Other Parts Discussed in Thread: LM5175
Hello team,
Is there any sample code which the customer is able to refer for DAC60504?
Austin
Hi Austin Do,
Sorry for delay response ,,here find the Generic example code sequence.'
Please note: set gain , divider factor based on your schematic and application.
Broadcast mode, DAC update using CS rising edge
<ADDR>, <DATA>
0x05, 0x000A // Trigger Register, Apply software reset and update DAC using async mode (CS rising edge)
0x05, 0x0000 // Trigger Register, Clear software register
0x02, 0xFF00 // SYNN Register , Disable brd cast and LDAC trigger - DAC update on CS rising edge
0x03, 0x0000 // CONFIG Register , Disable power down all dac channels, enable internal reference, Enable SDO
0x04, 0x000F // Select Gain buffer X2 and internal divider factor by 2
0x06, 0xYYYX // Board cast DAC for all DAC : { DATA[11:0], x, x, x, x}, DAC code
Normal mode, DAC update using CS rising edge
0x02, 0xF000 // SYNN Register , Enable brd cast and disable LDAC trigger - DAC update on CS rising edge
0x07, 0xYYYX // DAC ch0 for all DAC : { DATA[11:0], x, x, x, x}, DAC code
0x08, 0xYYYX // DAC ch1 for all DAC : { DATA[11:0], x, x, x, x}, DAC code
0x09, 0xYYYX // DAC ch2 for all DAC : { DATA[11:0], x, x, x, x}, DAC code
0x0A, 0xYYYX // DAC ch3 for all DAC : { DATA[11:0], x, x, x, x}, DAC code
0x05, 0x0010 // Apply LDAC SYNC to update all data at a same time
Anbu M
