Part Number: ADS131M06
Other Parts Discussed in Thread: ADS1262, ADS1234
Hello
I have an application where I need 6 simultaneously analog inputs
2 loadcells
2 potentiometer
2 4-20mA sensors
for petentiometere I will connect the negative analog inputs to ground ; the postive analoge will be from potentiometer with maxiumum volt 1.2V.
for 4-20ma I will use 50ohm resistor between postive and negative analog inputs and connect negative analoge input to ground .
for laod cells I will excite the laodcell of 8V and use 64 gain . can I connect the laodcell signals directly to the inputs ?
Could you pls varify my connections
Thank you
