TLC3548: TLC3548, Mode 11, CS Initiates Operations
Part Number: TLC3548
Dear Support Team.
When I use [ Mode 11, CS Initiates Operations ], after a select channel command is issued, does my controller need to wait for conversion time before next select channel command ?
  • Hi Iwase!
    Welcome to our e2e Forum!
    Great question on the TLC3548 too by the way!  After you set the CFR with your desired sweep sequence (Table 2; D[4:3]), you would write to the device as shown in Figure 19.  You send /CS low, write any CH nibble (0x0xxx for example) for each of the channels in your sequence.  You should see the INT pin go active and then you can send the Read FIFO command to get the conversion results from SDO.
  • Hi Tom
    Thank you for answer.
    You write "You send /CS low, write any CH nibble (0x0xxx for example) for each of the channels in your sequence.
    I would like to know whether I should wait conversion time between CH nibbles.
    [ CH nibble ] [ wait conversion ] [CH nibble ] [ wait conversion ] [wait INT] or [CH nibble ] [CH nibble ] [wait INT] ?
  • Hi Iwase,
    You should wait the conversion time between CH nibbles.
