Other Parts Discussed in Thread: AFE58JD32
Hi, team:
My customer use AFE58JD3LP in their ultrasound,
The DCLK of AFE58JD32 is output by AFE 480MHz, but the measured clock offset is very large, more than 6%. Minimum :448MHz, maximum: 515MHz.mean:480Mhz
The frequency of the Gaussian distribution centered on 503M,485M,469M,457M
The customer tests the ADC clock is 80Mhz ,Each chip uses 8 pairs of LVDS, From the test results, the ADC clock frequency is OK, but the DCLK offset is very large
Did you encountered similar issue, Could you give some debugging suggestions?
