Part Number: AMC1305M25
What are the functions of MOSFET and Gate driver? How to select mosfet parameters?
Hi Zhang,
Perhaps I do not understand your question. From the standpoint of the AMC1305M25, there is no direct relationship/function to the MOSFET and gate driver. The snippet you captured from the datasheet is simplified 'typical application' circuit. Generally speaking, the MOSFETs are connected to a DC Bus and switched on/off via PWM to create a switched current to a load which is sensed by a shunt resistor and fed to the AMC1305. Selection of the MOSFET is dependent on the application.
