ADS1298R: calculate the total noise for ADC system, need tech support from Precision ADC PADC
Part Number: ADS124S08
Other Parts Discussed in Thread: ADS1298R, TINA-TI, ADS1298,
upon review your presentation slide titled adcs-noise-measurement-methods-and-parameters-presentation.pdf   i encountered following issues:
1) page 16,  would you send me the excel sheet since the file was not embedded in the pdf file?
2) for ADS1298R,  i would like to initiate noise analysis on ECG application per your presentation slide.
a) ECG transducer data transfer rate is 2k SPS, ECG transducer data has a gain of 6. since ADS1298R has inherent filters applied already to the data stream from the decimation from 32 Ksps to 2Ksps, shall i use 2k sps or 32k sps  in table 1 of page 22 in the datasheet?
 section 8.1 in datasheet is discussion the noise generated from ADC convertor or noise generated from ADC including preamp, voltage ref source as well as ADC?
b) if the noise in section 8.1 only refer to ADC, what is the voltage reference chip i should use to mimic presentation slide page 3 to predict the integrated noise on ADS1298R?
c) if the noise in section 8.1 only refer to ADC, what is the preamp chip i should use to mimic presentation slide page 4 to predict the amplifier noise on ADS1298R?
e) i download Tina-TI software, would like to learn how to select the file for simulating amplifier noise and noise from reference voltage source?
in short,  i would like to learn to predict the noise on ADS1298R based on the presentation slide adcs-noise-measurement-methods-and-parameters-presentation.pdf
thanks
jason
  • Hi Jason Li,
    As per our other conversation where you asked similar questions about the ADS124S08, let's continue this discussion offline. If you have specific questions about the ADS1298, please post a new thread and someone from the appropriate team will respond to you
    Thanks!
    -Bryan
  • bryan,   what is the relationship between input referred noise and total ADC noise ?   how to use input referred noise to calculate total ADC noise including preamp, reference and ADC concerter ?
    thanks
    jason
  • Hi Jason Li,
    Since this post is not about the ADS1298, I moved this question to our other thread about the ADS124S08
    I am going to lock this thread for now, if you have questions specific to the ADS1298 please start a new thread and the appropriate engineer will reply. If you have general questions about ADC noise, you can continue to ask them in the other thread about the ADS124S08
    -Bryan
