Part Number: DAC7802
I'm using the CS lines (changing data between different CS rising edges) to clock in data instead of the WR line.
The datasheet doesn't describe the case in which WRn is tied low and CS_A/Bn are cycled to load data.
The block diagram shows CS and WR as topologically equivalent with regard to clock chain timing.
Is this right?
Should I use different values for setup and hold (than those specified for WRn) when using CS for loading data?
Thank you for your help!
