Hi everyone!
I'm currently trying to make the JESD204C-IP work on an Artix 7 FPGA from Xilinx. The documentation says it should work at when I talked to TI employee they say the same thing. But when I change the IP from GTX to GTP a lot of signal change and the Transceiver wizard IP doesn't seem to be compatible with the rest of the JESD204C IP. The big problem is changing the qpll to a simple pll in the GTP transceiver. There is also changes on the DRP but those changes seem less difficult to overcome.
So my question is: Is there an example somewhere on how to instantiate the transceiver IP with GTP transceiver? This would help a lot thanks!
Étienne
