Part Number: ADS8678
Hi there,
I am wanting to use this part for a current sensing application of 0-9V range with current sensing of 0-3A (0.3 ohm resistor). I understand due that due to the non-differential architecture the common mode voltage would be a problem for high side sensing?
Do you think this part would be suitable for low side current sensing where Bipolar input AIN_xP gets the positive voltage value of current drop across the resistor of voltage of maximum 1V (3 x 0.3 ohm) and AIN_xGND gets the value of the sense resistor ground?
Thanks in advance.
