Part Number: ADC3424
Other Parts Discussed in Thread: TPS7A20
I'm looking to use the ADC3424 and currently looking at the power supplies I provide for it. From Figure 121 of the datasheet I notice PSRR is generally 30-40dB across the frequency range. Can you confirm if this applies only to the analogue supply (AVDD) or will noise on the digital supply (DVDD) have the same effect? I don't see any mention of PSRR anywhere apart from Figs. 121 and 122.
I plan to supply AVDD with a nice clean 1V8 supply, trimmed with LDO and ferrite beads. I had hoped just to power the digital supply pins from the rail powering the FPGA that will be communicating with the device, but at present this is a noisy supply direct from SMPS.
If the digital supply needs to be low-noise I'll change the design, but obviously would rather not do so if it has no effect.
Can you please advise.
Gordon.
