Other Parts Discussed in Thread: ADS131M08,
/** * \copyright Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the * distribution. * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * */ #include "ads131m0x.h" #include "stm32f1xx_hal.h" #include "stm32f1xx_it.h" #include "string.h" #include "gpio.h" #include <stdlib.h> //**************************************************************************** // // Internal variables // //**************************************************************************** _adcConfM* adcConfM = NULL; _ADS131M08_ch ch; #define SPI_DEFAULT_TIMEOUT 100U //**************************************************************************** // // Internal function prototypes // //**************************************************************************** // //uint8_t buildSPIarray(const uint16_t opcodeArray[], uint8_t numberOpcodes, uint8_t byteArray[]); //uint16_t enforce_selected_device_modes(uint16_t data); //uint8_t getWordByteLength(void); uint16_t getRegisterValue(uint8_t address); HAL_StatusTypeDef ADS131M08_send_command(uint16_t cmd, uint16_t addr, uint16_t regs); HAL_StatusTypeDef ADS131M08_recv_response(uint16_t cmd, uint16_t addr, uint16_t regs, _sendFlg sendFlg); extern void ADS131M08_control_cs_signal(_signalState onOff); extern GPIO_PinState ADS131M08_read_cs_signal(); void restoreRegisterDefaults(void); extern uint8_t ADS131M08_wait_drdy_int(const uint32_t timeout_10ms); HAL_StatusTypeDef ADS131M08_startup(); float ADS131M08_convert_to_mVolt(uint32_t reg); void delay_us(uint32_t microseconds); void toggleRESET(void); uint8_t confirmBuf[2]; //***************************************************************************** // //! Getter function to access registerMap array from outside of this module. //! //! \fn uint16_t getRegisterValue(uint8_t address) //! //! NOTE: The internal registerMap arrays stores the last know register value, //! since the last read or write operation to that register. This function //! does not communicate with the device to retrieve the current register value. //! For the most up-to-date register data or retrieving the value of a hardware //! controlled register, it is recommend to use readSingleRegister() to read the //! current register value. //! //! \return unsigned 16-bit register value. // //***************************************************************************** uint16_t getRegisterValue(uint8_t address) { assert(address < NUM_REGISTERS); return adcConfM->sr.mp[address]; } //***************************************************************************** // //! Example start up sequence for the ADS131M0x. //! //! \fn void adcStartup(void) //! //! Before calling this function, the device must be powered, //! the SPI/GPIO pins of the MCU must have already been configured, //! and (if applicable) the external clock source should be provided to CLKIN. //! //! \return None. // //***************************************************************************** HAL_StatusTypeDef ADS131M08_init(_adcType adcType, SPI_HandleTypeDef* hspi) { HAL_StatusTypeDef result = HAL_OK; _adcConfM* adcConf; if(adcType == ADS131M08_ADC1) { adcConfM = (_adcConfM*)malloc(sizeof(_adcConfM)); memset(adcConfM, 0, sizeof(_adcConfM)); adcConfM->type = adcType; adcConfM->stat = ADS131M08_INIT; adcConfM->hspi = hspi; adcConfM->nReset.port = SYNC_RESET_GPIO_Port; adcConfM->nReset.pin = SYNC_RESET_Pin; adcConfM->cs.port = CS_GPIO_Port; adcConfM->cs.pin = CS_Pin; adcConfM->nDrdy.port = DRDY_GPIO_Port; adcConfM->nDrdy.pin = DRDY_Pin; adcConfM->bufLen = M08_WORDS_IN_FRAME * M08_WORD_LENGTH; // 9 Words x 24 Bits adcConfM->rxBuf = (uint8_t*)malloc(adcConfM->bufLen); memset(adcConfM->rxBuf, 0, adcConfM->bufLen); adcConfM->txBuf = (uint8_t*)malloc(adcConfM->bufLen); memset(adcConfM->txBuf, 0, adcConfM->bufLen); adcConf = adcConfM; } else { result = HAL_ERROR; return result; } // Reset Sequence HAL_GPIO_WritePin(adcConf->cs.port, adcConf->cs.pin, GPIO_PIN_SET); HAL_GPIO_WritePin(adcConf->nReset.port, adcConf->nReset.pin, GPIO_PIN_RESET); result = ADS131M08_startup(); if(result == HAL_OK) { adcConf->stat = ADS131M08_NORMAL; } else { adcConf->stat = ADS131M08_INIT_FAIL; } return result; } HAL_StatusTypeDef ADS131M08_startup() { int i=0; uint16_t regs=0; /* (OPTIONAL) Provide additional delay time for power supply settling */ HAL_Delay(50); /* (REQUIRED) Set nRESET pin high for ADC operation */ HAL_GPIO_WritePin(adcConfM->nReset.port, adcConfM->nReset.pin, GPIO_PIN_SET); /* (OPTIONAL) Toggle nRESET pin to ensure default register settings. */ /* NOTE: This also ensures that the device registers are unlocked. */ toggleRESET(); /* (REQUIRED) Initialize internal 'registerMap' array with device default settings */ restoreRegisterDefaults(); /* (OPTIONAL) Validate first response word when beginning SPI communication: (0xFF20 | CHANCNT) */ ADS131M08_send_command(ADS131M08_CMD_NULL, 0, 0); ADS131M08_send_command(ADS131M08_CMD_UNLOCK, 0, 0); if(HAL_OK != ADS131M08_recv_response(ADS131M08_CMD_UNLOCK, 0, 0, SEND_SYSTEM_CMD)) { return HAL_ERROR; } ADS131M08_send_command(ADS131M08_CMD_WAKEUP, 0, 0); if(HAL_OK != ADS131M08_recv_response(ADS131M08_CMD_WAKEUP, 0, 0, SEND_SYSTEM_CMD)) { return HAL_ERROR; } /* (OPTIONAL) Define your initial register settings here */ regs=(CLOCK_DEFAULT & ~CLOCK_OSR_MASK); regs|=CLOCK_OSR_256; ADS131M08_send_command(ADS131M08_CMD_WREG,CLOCK_ADDRESS, regs); if(HAL_OK != ADS131M08_recv_response(ADS131M08_CMD_RREG, CLOCK_ADDRESS, 0, SEND_REGISTER_CMD)) { return HAL_ERROR; } /* (REQUIRED) Configure MODE register settings * NOTE: This function call is required here for this particular code implementation to work. * This function will enforce the MODE register settings as selected in the 'ads131m0x.h' header file. */ ADS131M08_send_command(ADS131M08_CMD_WREG,MODE_ADDRESS, MODE_DEFAULT); /* (OPTIONAL) Read back all registers */ // Wakeup device // Ignore the first 5 conversion results to allow for the // output buffers to fill-up and the SINC3 filter to settle for(i = 0; i < 5; i++) { ADS131M08_wait_drdy_int(100); ADS131M08_control_cs_signal(RESET_SIGNAL); HAL_SPI_Receive(adcConfM->hspi, adcConfM->rxBuf, adcConfM->bufLen, SPI_DEFAULT_TIMEOUT); ADS131M08_control_cs_signal(SET_SIGNAL); } return HAL_OK; /* (OPTIONAL) Check STATUS register for faults */ } //***************************************************************************** // //! Toggles the "nSYNC/nRESET" pin to trigger a reset //! (LOW, delay 2 ms, then HIGH). //! //! \fn void toggleRESET(void) //! //! \return None. // //***************************************************************************** void toggleRESET(void) { /* --- INSERT YOUR CODE HERE --- */ HAL_GPIO_WritePin(adcConfM->nReset.port, adcConfM->nReset.pin, GPIO_PIN_RESET); // Minimum /RESET pulse width (tSRLRST) equals 2,048 CLKIN periods (1 ms @ 2.048 MHz) HAL_Delay(2); HAL_GPIO_WritePin(adcConfM->nReset.port, adcConfM->nReset.pin, GPIO_PIN_SET); // tREGACQ delay before communicating with the device again delay_us(5); // NOTE: The ADS131M0x's next response word should be (0xFF20 | CHANCNT). // A different response may be an indication that the device did not reset. // Update register array // restoreRegisterDefaults(); // Write to MODE register to enforce mode settings } //***************************************************************************** // //! Sends the specified SPI command to the ADC (NULL, STANDBY, or WAKEUP). //! //! \fn uint16_t sendCommand(uint16_t opcode) //! //! \param opcode SPI command byte. //! //! NOTE: Other commands have their own dedicated functions to support //! additional functionality. //! //! \return ADC response byte (typically the STATUS byte). // //***************************************************************************** HAL_StatusTypeDef ADS131M08_send_command(uint16_t cmd, uint16_t addr, uint16_t regs) { HAL_StatusTypeDef result = HAL_OK; _sendFlg sendFlg = SEND_SYSTEM_CMD; GPIO_PinState pinStat = GPIO_PIN_RESET; switch(cmd) { case ADS131M08_CMD_NULL: case ADS131M08_CMD_RESET: case ADS131M08_CMD_STANDBY: case ADS131M08_CMD_WAKEUP: case ADS131M08_CMD_LOCK: case ADS131M08_CMD_UNLOCK: adcConfM->txBuf[0] = ADS131M08_UPPER(cmd); adcConfM->txBuf[1] = ADS131M08_LOWER(cmd); adcConfM->txBuf[2] = 0; adcConfM->txBuf[3] = 0; adcConfM->command = cmd; adcConfM->regAddr = 0; sendFlg = SEND_SYSTEM_CMD; break; case ADS131M08_CMD_RREG: // ADS131A04_CMD_RREGS adcConfM->txBuf[0] = ADS131M08_UPPER(ADS131M08_REG_COMMAND(cmd,addr)); adcConfM->txBuf[1] = ADS131M08_LOWER(ADS131M08_REG_COMMAND(cmd,addr)); adcConfM->txBuf[2] = 0; adcConfM->txBuf[3] = 0; adcConfM->command = cmd; adcConfM->regAddr = addr; adcConfM->regs = regs; sendFlg = SEND_REGISTER_CMD; break; case ADS131M08_CMD_WREG: adcConfM->txBuf[0] = ADS131M08_UPPER(ADS131M08_REG_COMMAND(cmd,addr)); adcConfM->txBuf[1] = ADS131M08_LOWER(ADS131M08_REG_COMMAND(cmd,addr)); adcConfM->txBuf[2] = ADS131M08_UPPER(regs); adcConfM->txBuf[3] = ADS131M08_LOWER(regs); adcConfM->command = cmd; adcConfM->regAddr = addr; adcConfM->regs = regs; adcConfM->sr.mp[addr] = regs; sendFlg = SEND_REGISTER_CMD; break; default: break; } // Check availablity to send data while(GPIO_PIN_RESET == pinStat) { pinStat = ADS131M08_read_cs_signal(); } ADS131M08_control_cs_signal(RESET_SIGNAL); result = HAL_SPI_TransmitReceive(adcConfM->hspi, adcConfM->txBuf, adcConfM->rxBuf, adcConfM->bufLen, SPI_DEFAULT_TIMEOUT); ADS131M08_control_cs_signal(SET_SIGNAL); if(sendFlg == SEND_SYSTEM_CMD) { adcConfM->response = combineBytes(adcConfM->rxBuf[0], adcConfM->rxBuf[1]); } else if(sendFlg == SEND_REGISTER_CMD) { adcConfM->sr.mp[adcConfM->regAddr] = regs; } if(HAL_OK != result) { ADS131M08_control_cs_signal(SET_SIGNAL); } else { // DO NOTHING } return result; } HAL_StatusTypeDef ADS131M08_recv_response(uint16_t cmd, uint16_t addr, uint16_t regs, _sendFlg sendFlg) { uint16_t temp; // Initialize buffer to send NULL command HAL_StatusTypeDef result = HAL_OK; memset(adcConfM->txBuf, 0, adcConfM->bufLen); // Check availablity to send data while(GPIO_PIN_RESET == ADS131M08_read_cs_signal()) {} ADS131M08_control_cs_signal(RESET_SIGNAL); if(sendFlg == SEND_SYSTEM_CMD) { if(HAL_OK != HAL_SPI_TransmitReceive(adcConfM->hspi, adcConfM->txBuf, adcConfM->rxBuf, adcConfM->bufLen, SPI_DEFAULT_TIMEOUT)) { return HAL_ERROR; } adcConfM->response = combineBytes(adcConfM->rxBuf[0], adcConfM->rxBuf[1]); if(cmd != adcConfM->response) { return HAL_ERROR; } } else if(sendFlg == SEND_REGISTER_CMD) { // temp = ADS131M08_REG_COMMAND(cmd,addr); // confirmBuf[0] = ADS131M08_UPPER(temp); // // if(confirmBuf[0] != adcConfM->rxBuf[0]) // { // return HAL_ERROR; // } // else // { // memset(adcConfM->rxBuf, 0, adcConfM->bufLen); result = HAL_SPI_TransmitReceive(adcConfM->hspi, adcConfM->txBuf, adcConfM->rxBuf, adcConfM->bufLen, SPI_DEFAULT_TIMEOUT); memset(adcConfM->rxBuf, 0, adcConfM->bufLen); // result = HAL_SPI_Receive(adcConfM->hspi, adcConfM->rxBuf, adcConfM->bufLen, SPI_DEFAULT_TIMEOUT); adcConfM->sr.mp[adcConfM->regAddr] = combineBytes(adcConfM->rxBuf[0], adcConfM->rxBuf[1]); // } // // if(regs != adcConfM->sr.mp[adcConfM->regAddr]) // { // return HAL_ERROR; // } } else { // Do Nothing } ADS131M08_control_cs_signal(SET_SIGNAL); return HAL_OK; } //***************************************************************************** // //! Updates the registerMap[] array to its default values. //! //! \fn void restoreRegisterDefaults(void) //! //! NOTES: //! - If the MCU keeps a copy of the ADS131M0x register settings in memory, //! then it is important to ensure that these values remain in sync with the //! actual hardware settings. In order to help facilitate this, this function //! should be called after powering up or resetting the device (either by //! hardware pin control or SPI software command). //! //! - Reading back all of the registers after resetting the device can //! accomplish the same result; however, this might be problematic if the //! device was previously in CRC mode or the WLENGTH was modified, since //! resetting the device exits these modes. If the MCU is not aware of this //! mode change, then read register commands will return invalid data due to //! the expectation of data appearing in a different byte position. //! //! \return None. // //***************************************************************************** void restoreRegisterDefaults(void) { adcConfM->sr.mp[ID_ADDRESS] = 0x00; /* NOTE: This a read-only register */ adcConfM->sr.mp[STATUS_ADDRESS] = STATUS_DEFAULT; adcConfM->sr.mp[MODE_ADDRESS] = MODE_DEFAULT; adcConfM->sr.mp[CLOCK_ADDRESS] = CLOCK_DEFAULT; adcConfM->sr.mp[GAIN1_ADDRESS] = GAIN1_DEFAULT; adcConfM->sr.mp[GAIN2_ADDRESS] = GAIN2_DEFAULT; adcConfM->sr.mp[CFG_ADDRESS] = CFG_DEFAULT; adcConfM->sr.mp[THRSHLD_MSB_ADDRESS] = THRSHLD_MSB_DEFAULT; adcConfM->sr.mp[THRSHLD_LSB_ADDRESS] = THRSHLD_LSB_DEFAULT; adcConfM->sr.mp[CH0_CFG_ADDRESS] = CH0_CFG_DEFAULT; adcConfM->sr.mp[CH0_OCAL_MSB_ADDRESS] = CH0_OCAL_MSB_DEFAULT; adcConfM->sr.mp[CH0_OCAL_LSB_ADDRESS] = CH0_OCAL_LSB_DEFAULT; adcConfM->sr.mp[CH0_GCAL_MSB_ADDRESS] = CH0_GCAL_MSB_DEFAULT; adcConfM->sr.mp[CH0_GCAL_LSB_ADDRESS] = CH0_GCAL_LSB_DEFAULT; #if (CHANNEL_COUNT > 1) adcConfM->sr.mp[CH1_CFG_ADDRESS] = CH1_CFG_DEFAULT; adcConfM->sr.mp[CH1_OCAL_MSB_ADDRESS] = CH1_OCAL_MSB_DEFAULT; adcConfM->sr.mp[CH1_OCAL_LSB_ADDRESS] = CH1_OCAL_LSB_DEFAULT; adcConfM->sr.mp[CH1_GCAL_MSB_ADDRESS] = CH1_GCAL_MSB_DEFAULT; adcConfM->sr.mp[CH1_GCAL_LSB_ADDRESS] = CH1_GCAL_LSB_DEFAULT; #endif #if (CHANNEL_COUNT > 2) adcConfM->sr.mp[CH2_CFG_ADDRESS] = CH2_CFG_DEFAULT; adcConfM->sr.mp[CH2_OCAL_MSB_ADDRESS] = CH2_OCAL_MSB_DEFAULT; adcConfM->sr.mp[CH2_OCAL_LSB_ADDRESS] = CH2_OCAL_LSB_DEFAULT; adcConfM->sr.mp[CH2_GCAL_MSB_ADDRESS] = CH2_GCAL_MSB_DEFAULT; adcConfM->sr.mp[CH2_GCAL_LSB_ADDRESS] = CH2_GCAL_LSB_DEFAULT; #endif #if (CHANNEL_COUNT > 3) adcConfM->sr.mp[CH3_CFG_ADDRESS] = CH3_CFG_DEFAULT; adcConfM->sr.mp[CH3_OCAL_MSB_ADDRESS] = CH3_OCAL_MSB_DEFAULT; adcConfM->sr.mp[CH3_OCAL_LSB_ADDRESS] = CH3_OCAL_LSB_DEFAULT; adcConfM->sr.mp[CH3_GCAL_MSB_ADDRESS] = CH3_GCAL_MSB_DEFAULT; adcConfM->sr.mp[CH3_GCAL_LSB_ADDRESS] = CH3_GCAL_LSB_DEFAULT; #endif #if (CHANNEL_COUNT > 4) adcConfM->sr.mp[CH4_CFG_ADDRESS] = CH4_CFG_DEFAULT; adcConfM->sr.mp[CH4_OCAL_MSB_ADDRESS] = CH4_OCAL_MSB_DEFAULT; adcConfM->sr.mp[CH4_OCAL_LSB_ADDRESS] = CH4_OCAL_LSB_DEFAULT; adcConfM->sr.mp[CH4_GCAL_MSB_ADDRESS] = CH4_GCAL_MSB_DEFAULT; adcConfM->sr.mp[CH4_GCAL_LSB_ADDRESS] = CH4_GCAL_LSB_DEFAULT; #endif #if (CHANNEL_COUNT > 5) adcConfM->sr.mp[CH5_CFG_ADDRESS] = CH5_CFG_DEFAULT; adcConfM->sr.mp[CH5_OCAL_MSB_ADDRESS] = CH5_OCAL_MSB_DEFAULT; adcConfM->sr.mp[CH5_OCAL_LSB_ADDRESS] = CH5_OCAL_LSB_DEFAULT; adcConfM->sr.mp[CH5_GCAL_MSB_ADDRESS] = CH5_GCAL_MSB_DEFAULT; adcConfM->sr.mp[CH5_GCAL_LSB_ADDRESS] = CH5_GCAL_LSB_DEFAULT; #endif #if (CHANNEL_COUNT > 6) adcConfM->sr.mp[CH6_CFG_ADDRESS] = CH6_CFG_DEFAULT; adcConfM->sr.mp[CH6_OCAL_MSB_ADDRESS] = CH6_OCAL_MSB_DEFAULT; adcConfM->sr.mp[CH6_OCAL_LSB_ADDRESS] = CH6_OCAL_LSB_DEFAULT; adcConfM->sr.mp[CH6_GCAL_MSB_ADDRESS] = CH6_GCAL_MSB_DEFAULT; adcConfM->sr.mp[CH6_GCAL_LSB_ADDRESS] = CH6_GCAL_LSB_DEFAULT; #endif #if (CHANNEL_COUNT > 7) adcConfM->sr.mp[CH7_CFG_ADDRESS] = CH7_CFG_DEFAULT; adcConfM->sr.mp[CH7_OCAL_MSB_ADDRESS] = CH7_OCAL_MSB_DEFAULT; adcConfM->sr.mp[CH7_OCAL_LSB_ADDRESS] = CH7_OCAL_LSB_DEFAULT; adcConfM->sr.mp[CH7_GCAL_MSB_ADDRESS] = CH7_GCAL_MSB_DEFAULT; adcConfM->sr.mp[CH7_GCAL_LSB_ADDRESS] = CH7_GCAL_LSB_DEFAULT; #endif adcConfM->sr.mp[REGMAP_CRC_ADDRESS] = REGMAP_CRC_DEFAULT; } //**************************************************************************** // // Helper functions // //**************************************************************************** void ADS131M08_receive_data() { ADS131M08_control_cs_signal(RESET_SIGNAL); HAL_SPI_Receive_DMA(adcConfM->hspi, adcConfM->rxBuf, adcConfM->bufLen); } //***************************************************************************** // //! Takes a 16-bit word and returns the most-significant byte. //! //! \fn uint8_t upperByte(uint16_t uint16_Word) //! //! \param temp_word is the original 16-bit word. //! //! \return 8-bit most-significant byte. // //***************************************************************************** uint8_t upperByte(uint16_t uint16_Word) { uint8_t msByte; msByte = (uint8_t) ((uint16_Word >> 8) & 0x00FF); return msByte; } //***************************************************************************** // //! Takes a 16-bit word and returns the least-significant byte. //! //! \fn uint8_t lowerByte(uint16_t uint16_Word) //! //! \param temp_word is the original 16-bit word. //! //! \return 8-bit least-significant byte. // //***************************************************************************** uint8_t lowerByte(uint16_t uint16_Word) { uint8_t lsByte; lsByte = (uint8_t) (uint16_Word & 0x00FF); return lsByte; } uint32_t ADS131M08_convert_adc_data(const uint8_t* dataBuf) { uint32_t upperByte; uint32_t middleByte; uint32_t lowerByte; // The output data extends to 32 bits with eight zeroes(0b00000000, 1Byte) added to the least significant bits when using the 32-bit device word length setting, datasheet 38p upperByte = ((uint32_t) dataBuf[0] << 16); middleByte = ((uint32_t) dataBuf[1] << 8); lowerByte = ((uint32_t) dataBuf[2] << 0); return (upperByte | middleByte | lowerByte); } void ADS131M08_parse_adc_data() { uint8_t index; adcConfM->response = combineBytes(adcConfM->rxBuf[0], adcConfM->rxBuf[1]); for(ch = ADC_CH1, index = 1; ch < NUMB_ADC_CH; ch++, index++) { adcConfM->chData[ch].r = ADS131M08_convert_adc_data(&adcConfM->rxBuf[index * M08_WORD_LENGTH]); adcConfM->chData[ch].v = ADS131M08_convert_to_mVolt(adcConfM->chData[ch].r); } } float ADS131M08_convert_to_mVolt(uint32_t reg) { const float unitFS = 5000.0f / 8388607.0f; // unit: mV (if unit is V, calculated value is out of 'float' range) const uint32_t boundaryValue = 0x7FFFFF; // threshold of positive value int signFlg = 0; // +: 1, -: -1 // negative value if (reg > boundaryValue) { reg = (0xFFFFFF - reg) + 1; // if value is 0xFFFFFF, register is -FS/2^23. so plus 1 signFlg = -1; } // positive value else { signFlg = 1; } // convert register to mVolt return (unitFS * (float)reg * (float)signFlg); } //***************************************************************************** // //! Takes two 8-bit words and returns a concatenated 16-bit word. //! //! \fn uint16_t combineBytes(uint8_t upperByte, uint8_t lowerByte) //! //! \param upperByte is the 8-bit value that will become the MSB of the 16-bit word. //! \param lowerByte is the 8-bit value that will become the LSB of the 16-bit word. //! //! \return concatenated 16-bit word. // //***************************************************************************** uint16_t combineBytes(uint8_t upperByte, uint8_t lowerByte) { uint16_t combinedValue; combinedValue = ((uint16_t) upperByte << 8) | ((uint16_t) lowerByte); return combinedValue; } //***************************************************************************** // //! Combines ADC data bytes into a single signed 32-bit word. //! //! \fn int32_t combineDataBytes(const uint8_t dataBytes[]) //! //! \param dataBytes is a pointer to uint8_t[] where the first element is the MSB. //! //! \return Returns the signed-extend 32-bit result. // //***************************************************************************** int32_t signExtend(const uint8_t dataBytes[]) { #ifdef WORD_LENGTH_24BIT int32_t upperByte = ((int32_t) dataBytes[0] << 24); int32_t middleByte = ((int32_t) dataBytes[1] << 16); int32_t lowerByte = ((int32_t) dataBytes[2] << 8); return (((int32_t) (upperByte | middleByte | lowerByte)) >> 8); // Right-shift of signed data maintains signed bit #elif defined WORD_LENGTH_32BIT_SIGN_EXTEND int32_t signByte = ((int32_t) dataBytes[0] << 24); int32_t upperByte = ((int32_t) dataBytes[1] << 16); int32_t middleByte = ((int32_t) dataBytes[2] << 8); int32_t lowerByte = ((int32_t) dataBytes[3] << 0); return (signByte | upperByte | middleByte | lowerByte); #elif defined WORD_LENGTH_32BIT_ZERO_PADDED int32_t upperByte = ((int32_t) dataBytes[0] << 24); int32_t middleByte = ((int32_t) dataBytes[1] << 16); int32_t lowerByte = ((int32_t) dataBytes[2] << 8); return (((int32_t) (upperByte | middleByte | lowerByte)) >> 8); // Right-shift of signed data maintains signed bit #elif defined WORD_LENGTH_16BIT_TRUNCATED int32_t upperByte = ((int32_t) dataBytes[0] << 24); int32_t lowerByte = ((int32_t) dataBytes[1] << 16); return (((int32_t) (upperByte | lowerByte)) >> 16); // Right-shift of signed data maintains signed bit #endif } void delay_us(uint32_t microseconds) { uint32_t tickstart = HAL_GetTick(); uint32_t wait = microseconds * (HAL_RCC_GetHCLKFreq() / 1000000); while ((HAL_GetTick() - tickstart) < wait); }
