In my design I am using 3 ADCs ADC12DJ5200RF ICs, I have a query on Power supply sequencing of multiple ADCs.
As per the ADC datasheet recommendations,
- Vx11 (Analog and Digital supplies) regulator is enabled after the VA19 supply is good
- VA11 and VD11 are derived from a common 1.1-V regulator
Please refer attached Power scheme. As per the attached Power Sequencing 1V9 power good of adc1 will be connected to Analog 1V1 regulator enable of adc1 IC, similarly for adc1 and adc2 also.
but as Digital 1V1 supply is combined for all the ADCs, when should I enable Digital 1V1 supply regulator, should I use oring logic of 1V9 power enables or should I use saperate LDOs for Digital supply.
Is the attached powering scheme for ADCs recommended?
Please guide us.
