Part Number: ADC12DJ5200RF
Other Parts Discussed in Thread: ADC12DJ3200
Hi team,
One of our customer's issues,, could you please provide some troubleshooting suggestions
Hello, we have completed debugging ADC12DJ3200 recently. Now we are starting to debug the ADC12DJ5200, and their circuits are completely consistent.
Firstly, we use a single channel 10G sampling with the following settings:
ADC12DJ5200 uses JMODE1 mode, K=4
JESD_ CORE_ CLK=250MHZ
Refclk=250MHZ
ADC_ SYSREF_ CLK=FPGA_ SYSREF_ CLK=31.25MHZ
Using the Transport Layer test mode, it was found that the received data will have periodic errors, as shown in the image of data intercepted by ILA, and the red marked points indicate the erroneous data.
Next, we try 9.8G sampling and set it as follows:
JESD_ CORE_ CLK=245MHZ
Refclk=245MHZ
ADC_ SYSREF_ CLK=FPGA_ SYSREF_ CLK=30.625MHZ
Using the Transport Layer test mode, it was also found that the received data may have periodic errors, but the error points are different from when sampling 10G. The figure shows the data intercepted by ILA, and the red marked points indicate the error data.
Next, we use 8G sampling and set it as follows:
JESD_ CORE_ CLK=200MHZ
Refclk=200MHZ
ADC_ SYSREF_ CLK=FPGA_ SYSREF_ CLK=25MHZ
The operation is normal in this mode,
May I ask what may be the reason?
Amy Luo
The figure shows a part of the triangular wave.
