Problem with ADS1252
Hello everybody,I am now in trouble with the 24-bit high precision AD converter,I have look through the datasheet for times ,but I still can't get it . The datasheet said that the data output rate was scaled with the CLK , it give a list of how to adjust the data rate via your CLK . I programme it with exact the same time,but sometime it is right ,sometime it means nothing .I am a Chinese student ,I don't know if I put it clearly. But can anyone give me a example of this cheap???
  • Hi Chao,
    The data rate is going to scale linearly with the master clock that is used. Take a look at Table 1 and read the text explaining the delta sigma modulator on page 8 of the data sheet.
    That being said, depending on whether you are using DOUT/DRDY mode, Synchronization mode, or the Powerdown modes, the timing and behavior may change. Figures 12, 13 and 14 show timing examples of the three modes. If you are still having problems after reading through those pages and diagrams, I can help some more if you provide a little more explanation of your setup and timing. What is your timing when it works and what is it when it is not working. Any scope pictures would help as well.
    Tony Calabria
