Part Number: DAC3283EVM
Other Parts Discussed in Thread: DAC3283, CDCE62005
we have Interfaced the DAC3283 with the Iwave systems FPGA. We are able to configure the CDCE with following frequencies:
DAC clk : 614 MHz
FIFO OSTR clk : 19.2 Mhz
FPGA clk : 76.8 Mhz
Interpolation : 4x
We generate a square signal using FPGA clk inside FPGA and sent it to DAC.
Data clk : 307.2 MHz
Frame clk: 19.2 Mhz
Frequency of square signal :38.4 Mhz
We are trying to see DAC output at J3 connector after doing the necessary changes mentioned in section 4.1 of DAC3283 User Guide.
We have checked using oscilloscope that all above mentioned clock and data are reaching to DAC pins, But there is no output from J3. IOUT pins on DAC IC always shows constant 3.3V, even if data from FPGA is not present.
Configuration file is also attached, which is used to configure DAC3283 and CDCE62005.
Texas Instruments Inc. DAC32x2 EVM Register Configuration DAC32x2 Registers Address Data 00 30 01 31 02 00 03 10 04 FF 05 30 06 00 07 20 08 F5 09 7A 0A B6 0B EA 0C 45 0D 1A 0E 16 0F AA 10 C6 11 24 12 02 13 00 14 00 15 00 16 00 17 00 18 80 19 00 1A 00 1B 00 1C 00 1D 00 1E 24 1F 12 20 00 21 00 CDCE62005 Registers Freq:19.200000MHz Address Data 00 01040300 01 81400321 02 811C0302 03 81040303 04 01040304 05 381C0A85 06 04BE1F26 07 3D98F7F7 08 20001808 <Cluster> <Name></Name> <NumElts>9</NumElts> <Cluster> <Name>Freq Calculations</Name> <NumElts>6</NumElts> <EXT> <Name>VCO Freq Actual[MHz]</Name> <Val>2408.00000</Val> </EXT> <EXT> <Name>RF Freq Actual[MHz]</Name> <Val>2408.00000</Val> </EXT> <EXT> <Name>PFD Freq Actual[MHz]</Name> <Val>0.80000</Val> </EXT> <DBL> <Name>RF Stepsize [MHz]</Name> <Val>0.80000</Val> </DBL> <DBL> <Name>Fraction [KHz]</Name> <Val>0.00000</Val> </DBL> <DBL> <Name>CAL_CLK_FREQ [MHz]</Name> <Val>5.00000E-2</Val> </DBL> </Cluster> <Cluster> <Name>Freq Targets</Name> <NumElts>5</NumElts> <DBL> <Name>Ref Freq[MHz]</Name> <Val>76.80000</Val> </DBL> <EXT> <Name>RF Target [MHz]</Name> <Val>2408.00000</Val> </EXT> <DBL> <Name>INT Step (MHz)</Name> <Val>0.80000</Val> </DBL> <I8> <Name>Int/Frac Select</Name> <Val>0</Val> </I8> <Boolean> <Name>stop</Name> <Val>1</Val> </Boolean> </Cluster> <Cluster> <Name>Reg1</Name> <NumElts>9</NumElts> <I8> <Name>ADDR</Name> <Val>9</Val> </I8> <I16> <Name>RDIV</Name> <Val>96</Val> </I16> <I8> <Name>RSV</Name> <Val>0</Val> </I8> <I8> <Name>REF_INV</Name> <Val>0</Val> </I8> <I8> <Name>NEG_VCO</Name> <Val>1</Val> </I8> <I8> <Name>ICP</Name> <Val>0</Val> </I8> <I8> <Name>ICPDOUBLE</Name> <Val>0</Val> </I8> <I16> <Name>CAL_CLK_SEL</Name> <Val>12</Val> </I16> <I8> <Name>RSV 2</Name> <Val>0</Val> </I8> </Cluster> <Cluster> <Name>Reg2</Name> <NumElts>9</NumElts> <I8> <Name>ADDR</Name> <Val>10</Val> </I8> <U16> <Name>NINT</Name> <Val>3010</Val> </U16> <I8> <Name>PLL_DIV_SEL</Name> <Val>0</Val> </I8> <I8> <Name>PRSC_SEL</Name> <Val>1</Val> </I8> <I8> <Name>RSV</Name> <Val>0</Val> </I8> <I8> <Name>VCO_SEL</Name> <Val>2</Val> </I8> <I8> <Name>VCOSEL_MODE</Name> <Val>0</Val> </I8> <I8> <Name>CAL_ACC</Name> <Val>0</Val> </I8> <I8> <Name>EN_CAL</Name> <Val>0</Val> </I8> </Cluster> <Cluster> <Name>Reg3</Name> <NumElts>3</NumElts> <I8> <Name>ADDR</Name> <Val>11</Val> </I8> <U32> <Name>NFRAC</Name> <Val>0</Val> </U32> <I8> <Name>RSV</Name> <Val>0</Val> </I8> </Cluster> <Cluster> <Name>Reg4</Name> <NumElts>25</NumElts> <I8> <Name>ADDR</Name> <Val>12</Val> </I8> <I8> <Name>PWD_PLL</Name> <Val>0</Val> </I8> <I8> <Name>PWD_CP</Name> <Val>0</Val> </I8> <I8> <Name>PWD_VCO</Name> <Val>0</Val> </I8> <I8> <Name>PWD_VCOMUX</Name> <Val>0</Val> </I8> <I8> <Name>PWD_DIV124</Name> <Val>0</Val> </I8> <I8> <Name>PWD_PRESC</Name> <Val>0</Val> </I8> <I8> <Name>PWD_RESYNC</Name> <Val>0</Val> </I8> <I8> <Name>PWD_OUT_BUFF</Name> <Val>1</Val> </I8> <I8> <Name>PWD_LO_DIV</Name> <Val>1</Val> </I8> <I8> <Name>PWD_TX_DIV</Name> <Val>0</Val> </I8> <I8> <Name>PWD_BB_VCM</Name> <Val>0</Val> </I8> <I8> <Name>PWD_DC_OFF</Name> <Val>0</Val> </I8> <I8> <Name>EN_EXTVCO</Name> <Val>0</Val> </I8> <I8> <Name>EN_ISOURCE</Name> <Val>0</Val> </I8> <I8> <Name>LD_ANA_PREC0</Name> <Val>0</Val> </I8> <I8> <Name>LD_ANA_PREC1</Name> <Val>0</Val> </I8> <I8> <Name>CP_TRISTATE</Name> <Val>0</Val> </I8> <I8> <Name>SPEEDUP</Name> <Val>0</Val> </I8> <I8> <Name>LD_DIG_PREC</Name> <Val>0</Val> </I8> <I8> <Name>EN_DITH</Name> <Val>1</Val> </I8> <I8> <Name>MOD_ORD</Name> <Val>2</Val> </I8> <I8> <Name>DITH_SEL</Name> <Val>0</Val> </I8> <I8> <Name>DEL_SD_CLK</Name> <Val>2</Val> </I8> <I8> <Name>EN_FRAC</Name> <Val>0</Val> </I8> </Cluster> <Cluster> <Name>Reg5</Name> <NumElts>14</NumElts> <I8> <Name>ADDR</Name> <Val>13</Val> </I8> <I8> <Name>VCOBIAS_RTRIM</Name> <Val>4</Val> </I8> <I8> <Name>PLLBIAS_RTRIM</Name> <Val>2</Val> </I8> <I8> <Name>VCO_BIAS</Name> <Val>8</Val> </I8> <I8> <Name>VCOBUF_BIAS</Name> <Val>2</Val> </I8> <I8> <Name>VCOMUX_BIAS</Name> <Val>3</Val> </I8> <I8> <Name>BUFOUT_BIAS</Name> <Val>0</Val> </I8> <I8> <Name>RSV</Name> <Val>0</Val> </I8> <I8> <Name>VCO_CAL_IB</Name> <Val>0</Val> </I8> <I8> <Name>VCO_CAL_REF</Name> <Val>2</Val> </I8> <I8> <Name>VCO_AMPL_CTRL</Name> <Val>3</Val> </I8> <I8> <Name>VCO_VB_CTRL</Name> <Val>0</Val> </I8> <I8> <Name>VCO_MUX_GAIN</Name> <Val>0</Val> </I8> <I8> <Name>EN_LD_ISOURCE</Name> <Val>0</Val> </I8> </Cluster> <Cluster> <Name>Reg6</Name> <NumElts>8</NumElts> <I8> <Name>ADDR</Name> <Val>14</Val> </I8> <I16> <Name>IOFF</Name> <Val>128</Val> </I16> <I16> <Name>QOFF</Name> <Val>128</Val> </I16> <I8> <Name>VREF_SEL</Name> <Val>4</Val> </I8> <I8> <Name>TX_DIV_SEL</Name> <Val>0</Val> </I8> <I8> <Name>LO_DIV_SEL</Name> <Val>0</Val> </I8> <I8> <Name>TX_DIV_BIAS</Name> <Val>1</Val> </I8> <I8> <Name>LO_DIV_BIAS</Name> <Val>2</Val> </I8> </Cluster> <Cluster> <Name>Reg7</Name> <NumElts>14</NumElts> <I8> <Name>ADDR</Name> <Val>15</Val> </I8> <I8> <Name>RSV</Name> <Val>0</Val> </I8> <I16> <Name>VCO_TRIM</Name> <Val>32</Val> </I16> <I8> <Name>RSV 2</Name> <Val>0</Val> </I8> <I8> <Name>VCO_TESTMODE</Name> <Val>0</Val> </I8> <I8> <Name>CAL_BYPASS</Name> <Val>0</Val> </I8> <I8> <Name>MUX_CTRL</Name> <Val>1</Val> </I8> <I8> <Name>ISOURCE_SINK</Name> <Val>0</Val> </I8> <I8> <Name>ISOURCE_TRIM</Name> <Val>4</Val> </I8> <I8> <Name>PD_TC</Name> <Val>0</Val> </I8> <I8> <Name>IB_VCM_SEL</Name> <Val>0</Val> </I8> <I8> <Name>MIXLO_VCM</Name> <Val>4</Val> </I8> <I8> <Name>DCOFFSET_I</Name> <Val>2</Val> </I8> <I8> <Name>VCO_TRIM_SEL</Name> <Val>1</Val> </I8> </Cluster> </Cluster>
