Part Number: DAC3482
1. Does Sampling rate of 1.25GHz achievable only by interpolation?
2. What is the Clk that needed for the following modes?
Roy
Yes, the maximum interface rate of the DAC3482 is listed on the spec as 625MSPS only. Therefore, to achieve 1.25GSPS DAC rate, you will need interpolation
This is a very broad question that you will need to refer to the datasheet for detail. The datasheet will explain the clocks needed for the PLL reference clock, DATACLK, and OSTR. Please refer to appropriate sections. There are equations associated for each mode. We can address specific questions if the customer has specific concerns.
