Other Parts Discussed in Thread: ADS1014
Customer would
like to measurement the Voltage and have the following
question:
What does it means Negative input or
single-ended channel 2 input?
Shlomi
Shlomi -
The ADS1014 can be configured to connect with 2 singled-ended signals or 1 differential signal.
The differential signal is defined by a positive input, AIN0, and negative (inverting) input, AIN1. The differential signals are typically referenced to a common mode voltage. Differential inputs would allow for a negative signal to be input to the ADC that is powered by a single supply (example +5V).
Single ended signals would be defined by two signals on AIN0 and AIN1.
