Part Number: AMC1306M25
Hi expert,
We found in AMC1306 EVM, there's an 0ohm R3 shorted to AGND from AINN, what's the function? Why need this?
Many thanks!
Joyce
Hi expert,
Many thanks!
Joyce
Eva,
Customer is INFO CONVERGENCE with servo drives end use. They met similar issue with this e2e post((+) AMC1306M25: The Current sampling is not accurate of AMC1306M25. - Data converters forum - Data converters - TI E2E support forums). It's similar that if they use 0R resistor, noise will be huge, but if change to 1R resistor, noise will be gone. Customer wonders why should add the 0R resistor shorted to GND and why 0R resistor leads to noise.
Joyce
Hi Joyce,
The 0 Ohm resistor should not be a source of noise. It's probably a layout concern. I can take a look if that would be helpful. The resistor is not a requirement, so if removing it from their system or using a different resistor leads to better results, that is suggestable too.
Eva
