Part Number: ADS7142-Q1
Please help to review schematic, thanks.
DOVDD : 1.8V, both SCL and SDA are pull up to DOVDD.
This looks good! As Tom previously mentioned, depending on the type of signal to be sampled, the ADS7142-Q1 might require an input voltage buffer. Can you provide information on the input signal that they will be sampling? Will it be a relatively low or fast moving signal, and what sampling rate will they sample this signal?
Joel
Hello Joel,
This is used to remote the voltage change of the NTC as the temperature changes.
Since this would seem to be a slow moving signal for temperature sensing, I would expect this configuration to work well! Thanks for sharing.
Joel
