ADS131M08: How are the metrology-fir-table.c generated in ADCEnergyMetrologyLibrary SW_1.03?
Part Number: ADS131M08
Dears,
I used ADS131M08 for electricity meter related applications and ported the ADCEnergyMetrologyLibrary SW_1.03 library, which contains a metrology-fir-table.c . How is this coefficient generated?
The maximum sampling rate defined within it is:
INT_SAMPLES_PER_10_SECONDS == 80000 && MAINS_NOMINAL_FREQUENCY == 50 && PHASE_SHIFT_FIR_TABLE_ELEMENTS == 256
That's 8K sampling, but I need 16K sampling now,
need: INT_SAMPLES_PER_10_SECONDS == 160000 && MAINS_NOMINAL_FREQUENCY == 50 && PHASE_SHIFT_FIR_TABLE_ELEMENTS == 256以及INT_SAMPLES_PER_10_SECONDS == 160000 && MAINS_NOMINAL_FREQUENCY == 60 && PHASE_SHIFT_FIR_TABLE_ELEMENTS == 256,  corresponding coefficient table.
  • Hello Chu,
    This took some digging, as this was created some time ago, but here is what I discovered.  The library was written for an MSP432P4111 MCU, which is no longer supported, and TI reference design TIDA-010037.  I did manage to locate the authors and will ask if they can help.
  • Hello Chu,
    Author says to modify and build the attached "generate-phase-shift-table.c" using cygwin.
    Example -> g++ -o run generate-phase-shift-table.c
    It creates a file run.exe.
    To create the new table type "run"  the new table will appear in a separate console window.
     *  generate-phase-shift-table.c -
     *  Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/
     *  Redistribution and use in source and binary forms, with or without
     *  modification, are permitted provided that the following conditions
     *  are met:
     *    Redistributions of source code must retain the above copyright
     *    Redistributions in binary form must reproduce the above copyright
     *    documentation and/or other materials provided with the
     *    distribution.
     *    Neither the name of Texas Instruments Incorporated nor the names of
     *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
     *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
     *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
     *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
     *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
     *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
     *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
     *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
     *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
     *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
     *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    /* Generate a table of single tap FIR coeffs for phase shifting signals by
       +-1/2 a sample. */
    #include <stdlib.h>
    #include <stdio.h>
    #include <math.h>
    //gcc -o generate-phase-shift-table.exe generate-phase-shift-table.c
    // ./generate-phase-shift-table
    int betas[5000];
    int As[5000];
    #define SAMPLE_RATE           2,929.69
    #define FREQUENCY             50
    #define STEPS                 256
    #define X_PARAMETER           1
    //#define  M_PI                 3.14159265
    void generate_fir_table(float sampling_rate, float frequency, int steps)
        double beta;
        double omega;
        double phi;
        double D;
        double A;
        double a;
        int i;
        omega = 2.0*M_PI*frequency/sampling_rate;
        phi = omega/2.0;
        for (i = 0;  i < steps;  i++, phi -= omega/(double) steps)
            /* phi is now in radians */
            D = phi/omega;
            a = (1.0 - 2.0*D)*(1.0 - 2.0*D)*cos(omega)*cos(omega) + 4.0*D*(1.0 - D);
            beta = -((1.0 - 2.0*D)*cos(omega) - sqrt(a))/(2.0*(1.0 - D));
            A = 1.0/sqrt((cos(omega) + beta)*(cos(omega) + beta) + sin(omega)*sin(omega));
            /* Scale things */
            beta *= 32768.0;
            /* Never allow beta to quite reach 32768 */
            if (beta >= 32768.0)
                beta -= 1.0;
            A *= 16384.0;
            betas[i] = beta;
            As[i] = A;
    void fine_tune_filter_table_gains(float sampling_rate, float frequency, int steps)
        double omega;
        double rms_in;
        double rms_out;
        double last_amp;
        double amp;
        int i;
        int j;
        /* Optimise the filter taps, through simulation of the filter */
        //printf("omega = %f %f\n", omega, omega*180.0/M_PI);
        for (i = 0;  i < steps;  i++)
            do
                rms_in = 0;
                rms_out = 0;
                last_amp = 0.0;
                for (j = 1;  j <= 10000;  j++)
                    amp = 1500*sin(j*omega);
                    rms_in += amp*amp;
                    amp += (last_amp*betas[i])/32768.0;
                    amp *= As[i]/16384.0;
                    rms_out += amp*amp;
                    last_amp = amp;
                rms_in = sqrt(rms_in/10000.0);
                rms_out = sqrt(rms_out/10000.0);
                //printf ("%d %d %f %f\n", betas[i], As[i], rms_in, rms_out);
                if (rms_out < rms_in)
                    As[i]++;
            while (rms_out < rms_in);
    #if 0
        /* See how well the tune went */
            rms_in = 0;
            rms_out = 0;
            last_amp = 0.0;
                amp = 1500.0*sin(j*omega);
                rms_in += amp*amp;
                //rms_out += amp*amp;
                rms_out += amp*1500.0*sin(j*omega + (i - steps/2)*omega/(double) steps);
                last_amp = amp;
            //rms_in = sqrt(rms_in/10000.0);
            //rms_out = sqrt(rms_out/10000.0);
            printf ("%d %d %f %f %f\n", betas[i], As[i], rms_in, rms_out, rms_out/rms_in);
    #endif
    void output_fir_table(float sampling_rate, float frequency, int steps, const char *name)
        double omega;
        double phi;
        int i;
        printf("const int16_t %s[%d][2] =\n", name, steps);
        printf("{\n");
        phi = omega/2.0;
        for (i = 0;  i < steps - 1;  i++, phi -= omega/(double) steps)
            printf("    { %6d, %6d }, /* %3d: %7.4f deg */\n", betas[i], As[i], i, phi*180.0/M_PI);
        printf("    { %6d, %6d }  /* %3d: %7.4f deg */\n", betas[i], As[i], i, phi*180.0/M_PI);
        printf("};\n");
    int main( void )
        float sampling_rate;
        float frequency;
        int steps;
        int fine_tune_gain;
        sampling_rate = SAMPLE_RATE;
        frequency = FREQUENCY;
        steps = STEPS;
        fine_tune_gain = (X_PARAMETER == 'x');
        generate_fir_table(sampling_rate, frequency, steps);
        if (fine_tune_gain)
            fine_tune_filter_table_gains(sampling_rate, frequency, steps);
        printf("/* This file was generated automatically by generate-phase-shift-table */\n");
        printf("#include <inttypes.h>\n");
        printf("\n");
        printf("#include <emeter-toolkit.h>\n");
        printf("\n");
        printf("#include \"emeter-metrology.h\"\n");
        printf("#include \"metrology-structs.h\"\n");
        printf("\n");
        printf("#if !defined(__HAS_SD_ADC__)  ||  defined(REACTIVE_POWER_BY_QUADRATURE_SUPPORT)\n");
        printf("\n");
        printf("/* This FIR table is used to create accurate 90 degree phase shifts */\n");
        printf("\n");
        printf("/* FIR coefficients to correct specific phase shift angles at %.2fHz\n", frequency);
        printf("   and sampling %.2f times per second. There are %d steps\n", sampling_rate, steps);
        printf("   in this table. */\n");
        printf("\n");
        printf("#if SAMPLES_PER_10_SECONDS != %d\n", (int) (sampling_rate*10.0f));
        printf("#error This FIR table is for %.2f samples per second.\n", sampling_rate);
        printf("#endif\n");
        printf("#if MAINS_NOMINAL_FREQUENCY != %d\n", (int) frequency);
        printf("#error This FIR table is for %.2fHz.\n", frequency);
        printf("#endif\n");
        printf("#if PHASE_SHIFT_FIR_TABLE_ELEMENTS != %d\n", steps);
        printf("#error This FIR table is for %d steps per sample.\n", steps);
        printf("#endif\n");
        printf("\n");
        output_fir_table(sampling_rate, frequency, steps, "phase_shift_fir_coeffs");
        printf("\n");
        printf("#endif\n");
        return  0;
    It worked for me, but the second console window disappears, so I had to create a simple .bat file that calls run.exe and pauses the console output so I can copy contents.
    Example .bat file
    run.exe
    pause
  • Hi Chu,
    I believe you should be good to go from here. I'll go ahead and mark this post as resolved, but if you still need further assistance you can re-open it.
