Part Number: DAC3482
Other Parts Discussed in Thread: DAC3484
Hi Team,
For evaluating the DAC3482 I am using the EVM but its has only single ended output,
Is it possible to work in diff mode?
1. Please advise how to install the "DNI" resistors in order to work at differential mode?
2. Connectors to j1,j4,j5,j8 are not installed on this evaluation board, Which one of the connectors do I need to use?
3. Do I need to remove the baluns? Which one?
4. Please advise how to implement the LPF for cutoff of 260MHz (what values need be for the cap/ind)? Do TI have a Filter simulator design tool for this?
5. how can I test the power consumption of the DAC at the following conditions: Fsamp=1GHz Interpolation factor=2 , NCO and PLL are off?
thanks!
