Part Number: TSC2046E
Other Parts Discussed in Thread: TSC2046
Hi Team,
Currently, customer use TSC2046E with 2 problem which needs your help, thanks in advance:
Question about the BUSY signal:
From datasheet, when the CS signal is high, the BUSY signal is in high impedance state.
The question is under what conditions can BUSY be high even if CS is high? The attached screenshot is the abnormal waveform captured after the TSC2046 is initialized:
Question about the interrupt PENIRQ signal:
Set PENIRQ signal is high when idle. From datasheet, when the touch screen is clicked, an interrupt will be generated when the channel is sampled, and multiple interrupts will be generated in one cycle.
However, when the touch screen is clicked on customer board, the PENIRQ signal is always low. What is the reason for this?
BRs,
Francis
