Hello team,
Is it possible for this device to calibrate itself using FB pin or any other method?
Kei Kuwahara
Hi Kiei,
No, there is no self-calibration. What are you trying to calibrate?
Katlynne Jones
Hi Katlynne-san,
Customer is trying to calibrate the INL of the DAC.
Wouldn't it be possible to monitor the DAC output using FB pin, and calibrate the output manually?
Kei Kuwahara
Hi Kei-san,
The FB pin is not a monitor, it is the inverting input of the internal output buffer. It could be used as a sense connection to compensate voltage drop over long wire connections, but there is not a way to use it to calibrate out INL.
INL/DNL are tricky to calibrate. You'd have to measure and plot every DAC code and come up with a unique transfer function that matches the true curve of the DAC due to INL errors.
Katlynne
