DAC38J82EVM: TI204C-IP - Support for Artix ultrascale+ FPGA's
Part Number: DAC38J82EVM
Hello
We wish to use the JESD IP TI204C-IP in a Artix ultrascale+ FPGA. The official documentation does not list this FPGA series as supported. I would like to know if this is actually the case.
Thank you
M
  • Hi Ashunam,
    The Artix US+ FPGAs use similar transceivers as those found in the Kintex/Virtex US+ devices. If your part has GTH transceivers, kindly use the ZCU102 reference design as the starting point. For GTY transceivers, kindly use the VCU118 design. Please note that you will need to edit the transceiver settings through the transceiver wizard, as directly porting the project to the Artix part may result in the tool removing/clearing the transceiver configuration. The recommended approach will be to open the ZCU/VCU design in a separate instance of Vivado, open the transceiver wizard and manually copy the settings to the Artix US+ project's transceiver wizard.
    Ameet
