Part Number: DAC900-Q1
Other Parts Discussed in Thread: OPA354, OPA690
I am trying to take the output of the DAC and convert it to voltage from 0V to 6V. I am using a non-inverting op-amp with a gain of 6 to accomplish this. I have simulated the op-amp circuit (with a current source as a stand in for the DAC) and I believe that my circuit will work, but I what I am doing is not shown in the datasheet nor in the EVM schematic.
At my last schematic review, I was given the action item of making the schematic match the app notes in the datasheet. I am trying to avoid using a negative supply rail for the op-amp, otherwise I would just add a stage before amplifying the analog signal. I tried to use the single-ended example, but replace the cable with an op-amp.
So, my question is: am I going down the wrong path with my current schematic?
