ADS1248: ADS1248 interface with PT1000 using STM32
Part Number: ADS1248
Hi friends,
               I have interface Stm32f103c8t6 microcontroller with ADS1248 ADC to find the temperature value using PT1000 sensor. I got all necessary files for circuit design and source code for ADS1248 ADC in TI E2E support Forum page. But I did not know how to effectively use to find the temperature values using those files.so please explain how to I got values using that source code. I have attached all source code files and schematic in below. Please explain using below i mentioned  adc.c source code. Thank you advance for your response.
#include "def.h"
#include "adc.h"
static void setSpi1Clock(void)
	GPIOB->BSRR = 1 << 13;		// PB13
static void clrSpi1Clock(void)
	GPIOB->BRR = 1 << 13;		// PB13
static void setSpi1Mosi(void)
	GPIOB->BSRR = 1 << 15;
	//PB15
static void clrSpi1Mosi(void)
	GPIOB->BRR = 1 << 15;
	//PB15
static bool getSpi1Miso(u8 chan)
	if (chan) {
		return (GPIOB->IDR & (1 << 11)) != 0;
	} else {
		return (GPIOB->IDR & (1 << 14)) != 0;
// chip select
static void assertCs(u8 chan)
	if (chan) {
		GPIOB->BRR = 1 << 10;
		//PB10
	} else {
		GPIOB->BRR = 1 << 12;
		//PB12
// chip select per compensazione temperatura
static void releaseCs(u8 chan)
	if (chan) {
		GPIOB->BSRR = 1 << 10;
		//PB10
	} else {
		GPIOB->BSRR = 1 << 12;
		//PB12
static void assertReset(void)
	GPIOC->BRR = 1 << 3;	// PC3
static void releaseReset(void)
	GPIOC->BSRR = 1 << 3;
static void assertStart(u8 chan)
	if (chan) {
		GPIOC->BSRR = 1 << 13;
		//PC13
	} else {
		GPIOC->BSRR = 1 << 12;
		//PC12
static void releaseStart(u8 chan)
	if (chan) {
		GPIOC->BRR = 1 << 13;
		//PC13
	} else {
		GPIOC->BRR = 1 << 12;
		//PC12
// nota : shiftare 0xff = nop durante fase in cui si vuole lettura !!
static u8 spiAdcSendByte(u8 ch, u8 val)
	int i;
	u8 mask = 0x80;
	int ret = 0;
	for (i = 0; i < 8; i++) {
		delayFix();
		if (val & mask) {
			setSpi1Mosi();
		} else {
			clrSpi1Mosi();
		delayFix();
		setSpi1Clock();
		delayFix();
		ret <<= 1;
		ret |= getSpi1Miso(ch);
		clrSpi1Clock();
		mask >>= 1;
		delayFix();
	return ret;
static bool getDRDYConversionComplete(u8 chan)
	if (chan) {
		return (GPIOC->IDR & (1 << 1)) == 0;		// PC1
	} else {
		return (GPIOC->IDR & (1 << 0)) == 0;		// PC0
static void AdcSendSync(u8 chan)
	assertCs(chan);
	delayFix();
	spiAdcSendByte(chan, ADS1248_CMD_SYNC);
	spiAdcSendByte(chan, ADS1248_CMD_SYNC); // Send two bytes identical
	delayFix();
	releaseCs(chan);
static void AdcSendOneByteCommand(u8 chan, u8 cmd)
	assertCs(chan);
	delayFix();
	spiAdcSendByte(chan, cmd);
	delayFix();
	releaseCs(chan);
static void AdcSendSelfOcal(u8 chan)
	AdcSendOneByteCommand(chan, ADS1248_CMD_SELFOCAL);
// 'quanti'   riportato in formato 'umano' 1 = 1 registro, ecc...
// quanti compreso tra 1 e 16 al max
static void AdcWriteReg(u8 chan, u8 add, u8 *data, u8 quanti)
	assertCs(chan);
	delayFix();
	spiAdcSendByte(chan, ADS1248_CMD_WREG | add);
	spiAdcSendByte(chan, quanti-1);
	while (quanti--) {
		spiAdcSendByte(chan, *data++);
	releaseCs(chan);
static void AdcReadReg(u8 chan, u8 add, u8 *data, u8 quanti)
	assertCs(chan);
	delayFix();
	spiAdcSendByte(chan, ADS1248_CMD_RREG | add);
	while (quanti--) {
		*data++ = spiAdcSendByte(chan, ADS1248_CMD_NOP);	// Attention -> NOP (0xff) required!
	releaseCs(chan);
// vale solo se DRDY conversion complete
static u32 AdcReadConversion(u8 chan)
	u32 value;
	assertCs(chan);
	delayFix();
	spiAdcSendByte(chan, ADS1248_CMD_RDATA);
	value =  spiAdcSendByte(chan, ADS1248_CMD_NOP); // Attention -> NOP (0xff) required!
	value <<= 8;
	value |= spiAdcSendByte(chan, ADS1248_CMD_NOP); // Attention -> NOP (0xff) required!
	value <<= 8;
	releaseCs(chan);
	return value;
static void AdcStopContinuousRead(u8 chan)
	assertCs(chan);
	delayFix();
	spiAdcSendByte(chan, ADS1248_CMD_SDATAC);
	releaseCs(chan);
static void ConfigureTCInputMux(u8 chan, u8 tcIndex)
	// chan 0..1
	// index 0..3
	u8 tmp = (tcIndex << 3) | 7;			// ain7 neg channel
	AdcWriteReg(chan, ADS1248_MUX0_REGISTER, &tmp, 1);
	switch (tcIndex) {
	case 0 :
		tmp = 0xf0 | 0x08;		//da IOUT1 	(IDAC2 - IDAC1 disconnected)
		break;
	case 1 :
		tmp = 0xf0 | 0x09;		//da IOUT2 	(IDAC2 - IDAC1 disconnected)
		break;
	case 2 :
		tmp = 0xf0 | 0x04;		//da AIN4 	(IDAC2 - IDAC1 disconnected)
		break;
	case 3 :
		tmp = 0xf0 | 0x05;		//da AIN5 	(IDAC2 - IDAC1 disconnected)
		break;
	AdcWriteReg(chan, ADS1248_IDAC1_REGISTER, &tmp, 1);
void thermoThread(void)
	static embtime_t tmCold;
	static embtime_t tm;
	static u8 state = THERMOTHREAD_STATE_SETUP_START;
	static u8 currTcIndex = 0;
	static u32 val_ads1 = 0;
	static u32 val_ads2 = 0;
	u8 tmp;
	if (time_fired(tmCold)) {
		tmCold = time_ms(100);
		// Cold-Junction temperature updated every 100mS, not always
		temperatureBase = getTemperatureBase();
	switch (state) {
	case THERMOTHREAD_STATE_SETUP_START:
		// maybe we will do something here in the future...
		state = THERMOTHREAD_STATE_SETUP_HARDWARE_INIT;
		break;
	case THERMOTHREAD_STATE_SETUP_HARDWARE_INIT:
		clrSpi1Clock();
		assertReset();	//Put Chip in ResetMode (no operations)
		releaseReset(); //Release Reset Pin (start chip)
		releaseCs(SPI_ADS1248_ONE);
		releaseCs(SPI_ADS1248_TWO);
		assertStart(SPI_ADS1248_ONE);	// start pin must be asserted during ADC configuration!
		assertStart(SPI_ADS1248_TWO); // start pin must be asserted during ADC configuration!
		tm = time_ms(10);		// 4mS minimum
		state = THERMOTHREAD_STATE_SETUP_RESET_ADS;
		break;
	case THERMOTHREAD_STATE_SETUP_RESET_ADS :
		if (time_fired(tm)) {
			spiAdcSendByte(SPI_ADS1248_ONE, ADS1248_CMD_RESET);
			spiAdcSendByte(SPI_ADS1248_TWO, ADS1248_CMD_RESET);
			tm = time_ms(5);		// post reset time (0,6mS minimum)
			state = THERMOTHREAD_STATE_SETUP_STOP_CONTINUOUS_MODE;
		break;
	case THERMOTHREAD_STATE_SETUP_STOP_CONTINUOUS_MODE :
		if ((getDRDYConversionComplete(0) == SPI_ADS1248_ONE) ||
				(getDRDYConversionComplete(1) == SPI_ADS1248_TWO)) {
			break;
		AdcStopContinuousRead(SPI_ADS1248_ONE);
		AdcStopContinuousRead(SPI_ADS1248_TWO);
		tm = time_ms(100);
		state = THERMOTHREAD_STATE_SETUP_CONFIG_REGISTERS;
		break;
	case THERMOTHREAD_STATE_SETUP_CONFIG_REGISTERS:
			tmp = 0x28; // internal ref on, ref1 selected, normal operation
			AdcWriteReg(SPI_ADS1248_ONE, ADS1248_MUX1_REGISTER, &tmp, 1);
			AdcWriteReg(SPI_ADS1248_TWO, ADS1248_MUX1_REGISTER, &tmp, 1);
			tmp = 0x03;			// GAIN=1  SPS=40
			AdcWriteReg(SPI_ADS1248_ONE, ADS1248_SYS0_REGISTER, &tmp, 1);
			AdcWriteReg(SPI_ADS1248_TWO, ADS1248_SYS0_REGISTER, &tmp, 1);
			tmp = 0x04;		 //500uA current source DRDY normal mode
			AdcWriteReg(SPI_ADS1248_ONE, ADS1248_IDAC0_REGISTER, &tmp, 1);
			AdcWriteReg(SPI_ADS1248_TWO, ADS1248_IDAC0_REGISTER, &tmp, 1);
			tm = time_ms(500);
			state = THERMOTHREAD_STATE_SETUP_OFFSET_CALIBRATION;
		break;
	case THERMOTHREAD_STATE_SETUP_OFFSET_CALIBRATION:
			/* WE DO NOT WANT THE CALIBRATION
			 * If the system is powered without the first TC connected
			 * the calibration offset will cause wrong readings for
			 * all the TC's connected.
			 * We can't do it every reading because it takes
			 * about 400mS @40SPS ~ 200mS @80SPS
			ConfigureTCInputMux(SPI_ADS1248_ONE, 0);
			ConfigureTCInputMux(SPI_ADS1248_TWO, 0);
			AdcSendSelfOcal(SPI_ADS1248_ONE);
			AdcSendSelfOcal(SPI_ADS1248_TWO);
			state = THERMOTHREAD_STATE_SETUP_WAIT_END_CALIBRATION;
		break;
	case THERMOTHREAD_STATE_SETUP_WAIT_END_CALIBRATION:
		// Wait the DRDY for the end calibration before start Read-Loop
		if ((getDRDYConversionComplete(SPI_ADS1248_ONE) == 0) ||
				(getDRDYConversionComplete(SPI_ADS1248_TWO) == 0)) {
			break;
		releaseStart(SPI_ADS1248_ONE);
		releaseStart(SPI_ADS1248_TWO);
		state = THERMOTHREAD_STATE_SETUP_FINALIZE;
		break;
	case THERMOTHREAD_STATE_SETUP_FINALIZE:
		tm = time_ms(10); // wait 10mS before start loop readings
		state = THERMOTHREAD_STATE_LOOP_START;
		break;
	// Continuous Reading-Loop states
	case THERMOTHREAD_STATE_LOOP_START:
			ConfigureTCInputMux(SPI_ADS1248_ONE, currTcIndex);
			ConfigureTCInputMux(SPI_ADS1248_TWO, currTcIndex);
			state = THERMOTHREAD_STATE_LOOP_WAIT_DATA;
		break;
	case THERMOTHREAD_STATE_LOOP_WAIT_DATA :
			break;
		state = THERMOTHREAD_STATE_LOOP_READ;
		break;
	case THERMOTHREAD_STATE_LOOP_READ:
		val_ads1 = AdcReadConversion(SPI_ADS1248_ONE);
		val_ads2 = AdcReadConversion(SPI_ADS1248_TWO);
		state = THERMOTHREAD_STATE_LOOP_FINALIZE;
		break;
	case THERMOTHREAD_STATE_LOOP_FINALIZE:
		tcRawValues[0+currTcIndex] = val_ads1 >> 8;
		tcRawValues[4+currTcIndex] = val_ads2 >> 8;
		if (++currTcIndex == MAX_NUM_OF_SENSORS) {
			Pt1000ReadCounter++; // Increment Read Counter for PLC
			currTcIndex = 0;
		tm = time_ms(1); // wait 1mS before start a new reading
		break;
#ifndef __ADC_H__
#define __ADC_H__
// ADS1248 registers
#define ADS1248_MUX0_REGISTER    	0x00
#define ADS1248_VBIAS_REGISTER   	0x01
#define ADS1248_MUX1_REGISTER    	0x02
#define ADS1248_SYS0_REGISTER    	0x03
#define ADS1248_OFC0_REGISTER    	0x04
#define ADS1248_OFC1_REGISTER    	0x05
#define ADS1248_OFC2_REGISTER    	0x06
#define ADS1248_FSC0_REGISTER    	0x07
#define ADS1248_FSC1_REGISTER    	0x08
#define ADS1248_FSC2_REGISTER    	0x09
#define ADS1248_IDAC0_REGISTER   	0x0A
#define ADS1248_IDAC1_REGISTER   	0x0B
#define ADS1248_GPIOCFG_REGISTER 	0x0C
#define ADS1248_GPIODIR_REGISTER 	0x0D
#define ADS1248_GPIODAT_REGISTER 	0x0E
//SPI Commands
//Control Sistem
#define ADS1248_CMD_WAKEUP    		0x01
#define ADS1248_CMD_SLEEP     		0x02
#define ADS1248_CMD_SYNC      		0x04
#define ADS1248_CMD_RESET     		0x06
#define ADS1248_CMD_NOP       		0xFF
//Read Data
#define ADS1248_CMD_RDATA     		0x12
#define ADS1248_CMD_RDATAC    		0x14
#define ADS1248_CMD_SDATAC    		0x16
//Read Registers
#define ADS1248_CMD_RREG      		0x20
//Write Registers
#define ADS1248_CMD_WREG      		0x40
//Calibration
#define ADS1248_CMD_SYSOCAL   		0x60
#define ADS1248_CMD_SYSGCAL   		0x61
#define ADS1248_CMD_SELFOCAL  		0x62
// Thermo Thread StateMachine definitions
// Setup Phase
#define THERMOTHREAD_STATE_SETUP_START									0
#define THERMOTHREAD_STATE_SETUP_HARDWARE_INIT					10
#define THERMOTHREAD_STATE_SETUP_RESET_ADS							20
#define THERMOTHREAD_STATE_SETUP_STOP_CONTINUOUS_MODE		30
#define THERMOTHREAD_STATE_SETUP_CONFIG_REGISTERS				40
#define THERMOTHREAD_STATE_SETUP_OFFSET_CALIBRATION			50
#define THERMOTHREAD_STATE_SETUP_WAIT_END_CALIBRATION		51
#define THERMOTHREAD_STATE_SETUP_FINALIZE								60
// Loop Phase
#define THERMOTHREAD_STATE_LOOP_START										100
#define THERMOTHREAD_STATE_LOOP_WAIT_DATA								110
#define THERMOTHREAD_STATE_LOOP_READ										120
#define THERMOTHREAD_STATE_LOOP_FINALIZE								130
// Program Defines
#define MAX_NUM_OF_SENSORS						4
#define SPI_ADS1248_ONE								0
#define SPI_ADS1248_TWO								1
#endif
