Part Number: DAC81416
I was wondering if I could request some more details on the topology or even a block diagram of how differential mode works? I am wondering if a single DAC output is used to generate the differential outputs via manipulation of the buffer stage etc., or if each output in a pair is generated by its respective single-ended DAC separately.
I am basically trying to understand if one should expect all max errors such as gain offset, INL etc. to be doubled when using differential mode.
Many thanks for your help.
