ADS1247 system monitor
Other Parts Discussed in Thread: ADS1247
for ADS1247 SYSTEM MONITOR are the calculations below correct?
(The internal reference voltage must be enabled when measuring)
Power-Supply and Reference Monitor
Voltage [V] = Conversion Result * 4 * 2.048 [V] * 1 / ( 2^23 - 1 )
Internal Temperature Monitor
Voltage [V] = Conversion Result  * 2.048 [V] * 1 / ( 2^23 - 1 )
118 [mV] @ 25 [°C] and 405 [uV / °C]
Offset [mV] = 118 [mV] - 25 [°C] * 0.405 [mV / °C]  = 107.875 [mV]
Temperature [°C] = ( Voltage [mV] - 107.875 [mV] ) 0.405 [mV / °C]
Giuseppe
  • Guiseppe,
    Your calculations appear correct.  One thing you can do to double check your formula is to work it both ways with simple calculations and you should end up with the same answer you started with for your starting point.
    Bob B
